My new S213 Wagon, several mods to come!
Wire connected in the far left slot on the pink connector, then you place the fuse in the same slot once the pink connector is assembled in the housing.
did you have to swap the star emblem from the previous base unit to the illuminated one? Or did the illuminated unit come with the star?
Further I would like know when the star is always illuminated. Is it just depending on the Coming home/leaving home selected timing?
Thanks for your help.
When connecting the star according to my instructions it will light up as long as the ignition stays on.
I've found the base without the star badge on eBay. I believe that's noch the one you assembled right?
In this Video it's shown that at least the star can be dismantled from the old base unit. So I am wondering why the old star wont fit on the illuminated base?
Thanks, I really wish I could afford a 400 but I had to settle with an oil burner instead, I run a 220d with the new OM654 engine, it is tuneable but I havnt done anything to it just yet.
I have the same engine and i thought it was going to be not that great, but it's actually surprising.
Saw your titanium lug bolts, and want to add titanium lug bolts to my W213 sedan. There is a company here in the US that makes them for many cars, including Mercedes.....however, they do not have the wheel locking bolt for Mercedes. For anyone who is interested, here is the link: https://www.acerracing.com/ACERLug_Titanium_Lug_Nuts_Bolts-128-1.html...........titanium tends to be expensive, but Acer Lug bolts are excellent quality, and a reasonable price. (I have them on my Porsche, with the locks). I won't get them for my Mercedes until Acer offers the locking lug bolts. (I like my AMG wheels, and want to keep them!).
Perhaps if enough people ask Acer about titanium locks for the Mercedes wheels, they will consider making them.
Any idea where I need to connect it to if I only want the star to light up when my headlights come on?
buy the star unit and wiring harness from your dealer!
Star unit: A2138179800
Harness: A2058204400
Route the harness towards this box, lift the plastic cover above it for access.
Connect the ground connector to the ground point at the left front member ( follow the brown wires)
Push in the tabs and lift the front fusebox up, find the pink connector and loosen it downwards.
Drill a hole in the fuse box outer housing.
Route the cable through the hole and connect the crimped connector in the far left slot in the pink connector housing.
Reassemble and fit a 2 or 3A fuse in the new slot
Done, a 10-15 minute job!
thanks for help
