E-Class (W213) 2016 - 2023
Key Fob Not Detected
Old Apr 5, 2017 | 09:22 AM
makris0000's Avatar
Hello
This morning I got in my E300 and I tried to start it, but the car said key fob not detected. Has anyone found a way to fix this (besides getting the second key) or get around it? If I remember correctly, I think there is somewhere to insert the key if it is not working correctly?
I would take it to my local dealership but I do not have time this week.
Old Apr 5, 2017 | 09:48 AM
Forty9's Avatar
2017 Mercedes E400 wagon (formerly 1995 Honda Accord EX sedan)
Originally Posted by makris0000
Hello
Good morning. I do not have my new car yet, but I have seen in the videos that there is a slot on the right-hand side of the place where one can charge one's phone, in the front console, where the key can be inserted. I hope this solves your problem. With all best wishes!
Old Apr 5, 2017 | 11:43 AM
Proeliator2001's Avatar
E220d
Try to keep key away from your phone too, not in same pocket. Helps me get reliable keyless unlocking/locking.
Old Apr 5, 2017 | 02:49 PM
Drano64's Avatar
2018 GLC43
slot in the ashtray/cup holder cubby.
Old Apr 5, 2017 | 03:25 PM
c4004matic's Avatar
17 E43; 21 GLS580
+1
Unusual issue however. Try a new battery before you drive it to the dealer. Another thing that can interfere with the FOB is your cell phone.
Old Apr 5, 2017 | 07:25 PM
makris0000's Avatar
Thanks and I scheduled to bring it in on Friday since they are giving me a loaner (hopefully they don't turn on their word) and I told them to also do whatever software updates it may need because my navi and radio lags quite a bit. Also I'm going to have them check the windows because I think my rear windows go down slightly when opening and closing the doors so much.
I will provide an update on what ends up happening.
Old Apr 6, 2017 | 11:21 AM
konigstiger's Avatar
'71 Pinto
Reference bulletin LI54.21-P-064645 see here: https://mbworld.org/forums/e-class-w...ml#post6895295
Old Apr 6, 2017 | 05:28 PM
makris0000's Avatar
Thanks for that, I found a few other TSB's that need to be addressed as well which I will tell the dealership about. I am making a list currently for all the stuff they need to fix/check out.
Old Apr 7, 2017 | 01:37 PM
makris0000's Avatar
Well, I ended up waiting at the dealership for about an hour and had to reschedule my appointment because they could not provide a loaner vehicle. When I made the appointment I specifically stated I need a loaner and was assured by the lady I made my appointment with that I would have one. So Monday should be the day, I will provide an update later on.
UPDATE:
I brought my E300 in this morning and was provided a GLC300 loaner. They said it would be maybe a week because I gave them a list of stuff to check out along with the key fob not working.
Old Apr 17, 2017 | 04:06 PM
makris0000's Avatar
Heres an Update.
The dealership had my car for a week to check out the key (and various other issues I noticed) and they could not find any error codes or anything wrong with the key. They did updates to the car so maybe the update fixed it and then they tried the key? Who knows but so far its been working since I got it back this morning.
Old Jan 2, 2020 | 07:12 AM
becky9113's Avatar
w213
My 2016 e220d w213 was solved this problem by moving out the (+) (positive) socket of the main battery out
and put it back again. Then I could start my car again and also the warning message was disappeared.
Old Mar 11, 2020 | 10:41 AM
Egonvdv's Avatar
EQE SUV AMG-line 350+
a few times now i could not open the car as it did not detect the key in my pocket.
i had to unlock with the key itself which worked fine
it's like the key has put itself in off mode (which you normally do by clicking "lock" quickly 2 times)
i though it might be a sign that the battery is getting weak, but then again,
the key works fine to open & close manually and als have no problem with starting the car…
already reset the key by taking out the battery, but problem still occurs every now & then.
any thoughts?
Old Jan 1, 2021 | 08:41 AM
Frank Marullo's Avatar
2017 e300
Did disconnecting the battery cause any other issues such as window and sunroof calibration etc.? I'm having this same issue, leery of disconnecting battery because of these concerns.
Old Nov 4, 2021 | 12:06 PM
stacks66's Avatar
w213 3220d
Same thing happened to me anyone know the route cause of this error though
same thing happened anyone know the origin of the problem for future this worked for me thank you Becky
Old Apr 4, 2026 | 07:42 AM
seedy's Avatar
E220d Premium Plus
six years later and I found this post which sorted my problem out
thank you
