Fine Tuning
Has anyone looked into fine tuning there car. I want to get a little more HP from my car and I was looking into Fine Tunning the engine. Do anyone recommend a certain company/brand of fine tunning?
Thanks,
SirJulian
None of us can say how close Mercedes have optimized every component in the engine and drivetrain. Ideally they'll have set it up so that each component is just good enough to withstand the expected loading plus a degree of standard deviation to account for varying use cases. What I mean is that they'll have a number of design cases to meet and one of them should envelope how the vast majority of customers will likely use the car. Drive aggressively all the time in harsh ambient conditions and it's likely your engine will go bang far before a typical commuter. So you could tune the engine a bit and as long as you're using it sympathetically you may never have trouble. But you can't be sure as, like I said, none of us know what reserve factors and margins are built in to every component of our cars.
In reality id bet there is a fair margin in a bread and butter car to increase power as it's not worth the risk of tight optimization in case you end up on the wrong side of conservatism. If they get the maths wrong and parts wear out or break quickly it's a huge warranty cost to bear. So it's a numbers game really of driving out material and manufacturing costs versus reliability versus performance.
And on top of that, there is variabilities in material stock, manufacture and assembly so two "identical" cars may respond very differently when tuned. Up the power, you up the mean stress the engine is exposed to. Higher mean stress causes more damage per cycle. The higher mean stress (and thus higher peak alternating stress) may now end up killing one engine in a month whilst the other battles on for 5 years. Luck of the draw really. Modern cars have high repeatabililty in their manufacture but just because John tuned his car and it's fine doesn't mean yours will be.
I wouldn't even mess with the tune of a car that is in warranty and really, if you want more power it's always better to start off with more power (as in an e43 or 63) than to eke out a few more bhp from what you've got.
Oh and a few bhp will make sod all difference anyway. Flat out acceleration, in my various experiences, only differ enough when there's a good 50bhp or more gulf between cars of similar weight and even then, in the context of road use, it's usually a small enough difference to only matter if you're insecure about your manhood.
The turbo 4 in the new E300 is already pretty much setup for what can be deliver safely and consistently over the projected life of the vehicle. Sure you can probably get someone to squeeze an extra 10 or 15 hp out of the already highly-tuned engine, but you're not going to notice that small difference. So it would be a waste of money on your part.
The E300 was designed for a specific ownership demographic and it fills the needs of that demographic quite well from all the feedback I've heard from those that bought it. If you're interested in noticeably more "get up and go" or a more performance oriented ride and feel, then as Proeliator2001 has already pointed out, you simply need a different vehicle to start out with. These newer model E's, with the exception of the AMG E63S, are already pretty much set at the upper limits of what they can produce safely.
