w213 fuse diagram
Attached is a cross referenced list of each fuse block, fuse number, amps and function from the images posted by Egonvdv. Note that there are several undefined locations/functions. I have not checked the data against what is physically present in the fuse blocks. Use at your own risk.
E 300 AMG-Line diesel-Hybrid - 2021
I really can't find the path to pass to the trunk. I might be dumb or something lol I have looked everywhere.
Can you show me a picture from where you passed? I can arrive to the back seats, it is easy but from there to the trunk I don't know.
I would highly appreciate it.
EDIT: Yes, I do need a switch fuse. A fuse that will turn off when the car is off, otherwise it is what you said, it will drain the battery.
I have not tested them yet, but the power window 30A fuses may be switched. If they are, I'll use the driver's side fuse panel for the dash cam since the F800 Pro is best suited for a left side installation. It would block the driver's view if mounted in the center below the mirror & sensor housing.
Gotic4u (06-14-2018)
#32
HI
just share my experience.
I use Vico Vation power-plus hard wired on front passenger side fuse box F318 ,5A.
the dash cam can use parking mode for hours before reach 12.1V cut
off point. you can set up you own cut off Voltage and no need to worry drain battery.
#33
It sucks but thats how it works. lol
Model W213 we talking
#35
Sadly, my DR900S died today lol. It is having a problem of overheating. A lot of friends in another forum are reporting the same problem, mostly in parking mode.
alfster1 (06-14-2018)
#36
#38
I really hate to resurrect this thread as a new member but i cannot seem to find a path for the wire from the rear passenger seats to the trunk. On the right passenger side (as if you are sat in the car, in the uk this is drivers side) i can pull the upholstery piece of interior where the seat belt rests but there is no obvious path to the trunk.
My car is e220d 2017 amg line saloon. My rear seats do not fold down as its a saloon...
Id really appreciate any help at all. what i thought would be a 1hr job is turning into a real nightmare!
#39
You should remove the plastic foot well trim.
Then lift the seat up and literally shove it underneath. There is a clip or a bolt holding it in the back rear corner so try to snake it behind it.
And then snake it behind the seat belt bolt
Needs to go under the rear plastic
#40
Okay I will try this on Sunday as I’m in Glasgow tomorrow on business. So if understand the rear seat lifts up from the bottom near the plastic on the side of the footwell then snake it through. I will let you know the results Sunday.
#41
Issue with running the wire to the boot
Hi,
my W213 is a long wheel base (India) with electric rear seats.
So can someone help me run the wires to the boot as the seats cannot be folded or removed
#43
is there really not a fuse box up front to top into for radar and dash cam? I don't think my hard wire kit cable is long enough to run all the way to the back of the car and still be able to mount on the windshield
#44
#45
Save yourself the hassle and get an plug and play into the automatic wiper sensor. Literally a 5 min job from start to finish (10 if you count linking the camera to your phone)....
#46
https://youtu.be/YBamKNm6yP4?feature=shared
#47
There are several fuses in the engine compartment driver's side fuse box that are switched. Circuit 111 has a 30 amp fuse that is easy to access. The driver's side door fuse box is difficult to access. Circuit 214 has a 30 amp fuse.
