E-Class (W213) 2016 - 2023
w213 fuse diagram
Old Mar 13, 2024 | 02:02 PM
  #51
chadparkerlaw's Avatar
2018 w213 E400
W213 E400 Window Switch
Hello,
I am new here, so I apologize if this is not the correct way to post/ask questions. I have a 2018 E400 Base coupe. A few weeks ago, my driver's side window switch stopped working. All of the labeled fuses look right. When I use the key fob or passenger side, everything works. I took it to the dealership, and they were nice enough to tell me I could order a new switch cheaply. They told me it was the switch. The switch has been installed, and no power is going to the switch; it never did; the dealership was wrong and never tested the power. The window fuses seem to be higher voltage for the motors, which work.
I have traced everything back and can't find the lower voltage relay that connects to the switch. It looks like it would go to its own fuse, but I am stumped. Does anyone know which fuse controls the switch? Any help would be so appreciated.
Old Mar 13, 2024 | 02:19 PM
  #52
ua549's Avatar
Did you check fuses 203 and 214? They are both located in the driver side dashboard panel.
AFAIK those are the only fuses that control power windows.
Old Mar 13, 2024 | 04:06 PM
  #53
2018 w213 E400
hi, thanks so much for your reply. Yea both of those fuses power the motors and those work fine. It’s the drivers side master switch not getting power to it. Seems unlikely that it would have its own dedicated fuse but I keep looking.
Old Mar 14, 2024 | 11:05 AM
  #54
Diesel Benz's Avatar
The power windows switch group is powered by the door control unit, no separate fuse for that (fuse 203 as mentioned above for the door control unit) . What are you referring to with the "master switch"? The switch group should have 30t power (not always on), ground and LIN bus only for wiring.
Old Jul 16, 2024 | 03:50 PM
  #55
mau22's Avatar
mercedes benz E450 4matic coupe
I need to conect a dashcam to the fuse box, red cable to a ACC, yellow to B+ and blac
QUOTE=ua549;7466745]Use a voltage tester to see if power is on the fuse when the car is turned off. Then make sure there is power when the car is switched on. With dash cams that include park mode, you'll need a connection to both switched and constant power plus ground - 3 connections total.[/QUOTE]
can anybody suggest the # fuse to use?
Old Feb 27, 2025 | 07:10 PM
  #56
groker's Avatar
Originally Posted by Bfgslkman
Save yourself the hassle and get an plug and play into the automatic wiper sensor. Literally a 5 min job from start to finish (10 if you count linking the camera to your phone)....
https://youtu.be/YBamKNm6yP4?feature=shared
Hi, is the voltage from this connector acc or constant 12v?
Old Mar 21, 2025 | 04:06 PM
  #57
natesamg's Avatar
2020 E53 AMG Sedan
in the pax front side footwell box is there both a ignition based fuse and a constant one?
