E-Class (W213) 2016 - 2023
Manually Activate Cameras
Old Oct 23, 2017 | 03:41 PM
ua549's Avatar
Is there a way to manually activate the 360° camera view? Many times I'm within a foot of an obstacle before the cameras activate.
Old Oct 23, 2017 | 06:02 PM
nashvilletn's Avatar
2017 E300
should be a button to the left of the steering wheel above the light switch
Old Oct 23, 2017 | 06:39 PM
c4004matic's Avatar
17 E43; 21 GLS580
Checked today. You cannot manually activate the 360. You can activate all the other views manually using the camera button on the center console except the 360 which is automatically activated only when the sonar beeps activate or when comming out of park. Just slow down also set the parking warning to "early" in the additional audio settings.
Old Oct 25, 2017 | 01:52 PM
achance's Avatar
2017 E300 Sport
I would like to manually active the cameras as well. A work-around I do when I'm pulling into a parking spot and need the cameras is to put the car in reverse and then put it back into drive. This will keep the cameras on as long as you are driving slow enough.
Old Oct 25, 2017 | 02:46 PM
knoppe01's Avatar
2020 E350, 2019 GLC 300
Ditto - I do the same thing - it's an easy work around and saves curbing the front air dam
Old Oct 25, 2017 | 03:34 PM
c4004matic's Avatar
17 E43; 21 GLS580
+1
Old Oct 25, 2017 | 04:06 PM
vic viper's Avatar
S213
Just push the parking spot scan button and swipe the pad right, then you will get 360 view and the desired view to the right, preferably the front wheel view in my case.
Old Oct 25, 2017 | 06:35 PM
c4004matic's Avatar
17 E43; 21 GLS580
Vic you can activate any of the cameras but not the 360 degree view. If you press the camera button, the 360 view will show an animation of the radar sensors, the 360 view will only activate when the proximity sensors start beeping. If you know of another way let us know.
Old Oct 26, 2017 | 06:40 AM
vic viper's Avatar
S213
Well, here I get both chosen view AND the 360 view when doing as I described.
Old Oct 26, 2017 | 03:14 PM
ua549's Avatar
I got it to work! The default view seems to be the animation, but when I scroll I can select any of the parking assist views - 360 in left pane and front/rear/surround in the right pane.
That said, speed is critical when activation takes place. Mine works under 15 mph otherwise it shuts off immediately.
Old Oct 26, 2017 | 05:15 PM
c4004matic's Avatar
17 E43; 21 GLS580
Ill give it another try!
Old Oct 27, 2017 | 07:50 PM
c4004matic's Avatar
17 E43; 21 GLS580
Got it to work too thanks Vic.
