Engine Coolant Temperature Display - Where?
I can't find the Engine Coolant Temperature Display.
Is there such a display or only a red light if engine overheats?
Does it depend on the settings, according to the manual the W213 has a similar coolant temperature indicator as I have on the 222. The indicator is first blue but at decent temperatures it gives actual values.
I’ve found it in the menu ... quite a hassle to check engine temp. No other indicator?
thanks.
I do use the temperature gauge in cooler weather and don't let the engine hit any decent revs until the engine's almost up to normal operating temperature. It may be old fashioned, but I got 225,000 miles out of my last car and hope to do the same out of my new one. With the newer engines being lighter & made of lighter castings, I'm thinking it's probably an even better idea now.
CORRECTION: this show the oil temp...
I use the progressive display, but have "driver assist "
activated so it shows the car in front of me and not the engine temp!
This is strange, because the 2017 has the temp display at the bottom of the dial. Strange that they removed it.
One question: Does your engine warm up very slowly ... something like 15 minutes? My previous 2015 C300 (same engine) was very fast to warm up.
