E-Class (W213) 2016 - 2023
W213 computers
Old Dec 1, 2017 | 08:59 AM
zvenxyn's Avatar
W213
W213 computers
Hello,
maybe someone knows how much controllers are in W213 E300 2017 model?
Thanks!
Old Dec 1, 2017 | 09:59 AM
ua549's Avatar
They are called controllers and there are several. Pricing is from expensive to very expensive. You'll need part numbers for pricing in your market area.
Old Dec 1, 2017 | 11:07 AM
zvenxyn's Avatar
W213
And how much controllers there in? I preparing for my purchase of E300 2017 with flood damage and i'm wondering how much controllers I will need to change if some.
And can I buy some used controllers and put in to the car? I work as a software engineer / electronics engineer, so my background is in electronics stuff, so most of the repairs I would do by my self.
Old Dec 1, 2017 | 11:17 AM
ua549's Avatar
Sorry, I am not a MB mechanic. I suggest you get one to do full diagnostics on the car before you purchase it.
Old Dec 1, 2017 | 11:30 AM
zvenxyn's Avatar
W213
hmm.. the car I will buy is from auction and I can't do full diagnostics.
I'm just wondering if the W213 can be repaired after flood damage, the water line is up to windows. I'm thinking that ECU will be working because the ECU box is very sealed.
Old Dec 1, 2017 | 11:40 AM
Lanzz's Avatar
2024 E450 AT Wagon, 2024 EQS450+ / Had: 2021 E350, 2019 E300, 2021 + 20 GLE350, 2019 E450 Wagon(s)
Given the complexity of the electrical architecture of E Class, and any modern luxury auto, I would expect a good amount of diagnosis and trial and error to get that car back to being reliable. There are several experts on this forum who may be able to advise you better. I've spent my entire career in technology, and I am honestly baffled by the complexity of the E-Class electrical system.
Your project sounds cool, best of luck and take lots of pictures!!
e
Old Dec 1, 2017 | 11:44 AM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
#1) If the car was flooded up to its windows, it's not worth salvaging. Unless it's a rare 1955 Chevy that you're planning on gutting to the frame and starting over, you'll never be able to get the mold/mildew/etc., out of the car. At the very least, all interior trim is a gonner, if not a biohazard. If the car's sitting at auction, then you know no one's bothered to clean it up, so the mold keeps growing.
#2) You're going to need access to a Mercedes Xentry system. These aren't cheap. Worse, they require an annual subscription from Mercedes which is even pricier. Even if you are able to get the right parts, you'll still need to code them to match the car's VIN# and matching equipment list.
#3) The W213 is a computer on wheels, not a car. Flip through the forum and you'll see that even on a good day, keeping the electronics happy on a factory-new MB isn't always easy for the dealers who work on these cars every day. If you're not familiar with them, forget it.
I hate to be such a downer, but I'm a techie as well. If you have a smart phone, it likely contains algorithms I designed 20 years ago. I've worked on industrial production lines, avionics, broadcast facilities, etc. Even I won't tackle repairing a flooded MB.
Old Dec 1, 2017 | 12:00 PM
zvenxyn's Avatar
W213
Ok, thanks for the answers!
I heard that I can diagnose/reprogram not only with Xentry but with iCarsoft MB like tools. Is this correct?
If yes then I would skip all the Xentry expensive devices and software.
Old Dec 1, 2017 | 12:05 PM
Lanzz's Avatar
The man to ask on this forum is @konigstiger. He's the encyclopedia of all things Benz. Also, there is knowledgeable MB technician from S Florida with an S600 Coupe who posts great technical details... can't recall his name.
Old Dec 1, 2017 | 12:31 PM
cetialpha5's Avatar
Here's a key question, does the car run? If it runs, maybe you have a shot at fixing it. But if it doesn't, the sky's the limit. The problem with a 2017 is that it's so new, you'll only be able to get parts from an MB dealer, you won't get much luck finding parts at a junkyard so no, you probably won't find used parts. And of course with a flood vehicle that's salvage, there would be no MB warranty. Flood vehicles are only good for parts for say a body part like a door or hood/trunk. Once salt water gets in, all the parts will eventually corrode and even if you fix it, years down the road you will be chasing electrical gremlins that no one else knows about because they don't have a flood car. I would skip any car that was up to the windows, maybe if it was just the floorboards and that's a tough maybe.
Old Dec 1, 2017 | 06:41 PM
petee1997's Avatar
...24 GLE53
Stay away from this car!!!! This car is worth whatever the value of the body parts. To redo the electrical and interior is more costly than buying a new one.
Old Dec 2, 2017 | 03:39 AM
Diesel Benz's Avatar
I tried Xentry simulation for a 213.048, gives 75 control units plus some 30 minor LIN bus controllers.
Not necessarily all are damaged, at least one is on the roof that water has not reached in this case.
