Programming garage door with a keyless entry pad?
The keyless pad is from Chamberlain, and I reckon it is this model:
https://www.chamberlain.com/clicker-...ireless-keypad
All the videos I found online and user manual shows I need to program the garage with a remote, nowhere mentioned if a keyless entry pad would also work.
My understanding the keyless entry pad is also using radio to communicate with the garage door remotely. So theoretically, it works just like a remote control but with a PIN.
Thank you.
I don't think it is hard wired. It is just installed on the frame of garage door and communicate with the garage door motor wirelessly.
But keep it in the car and enter a PIN every time open and close the garage door seems a hassle. If this is the case, I probably spend 30-40 dollars to get a remote instead.
Sure, I will try that, otherwise will buy a universal remote either online or from local shop.
Thank you.
P.S. how's your car? I just got mine last week, everything perfect but it is a pity North America version doesn't have the remote parking feature for 2018 model.
. Yes, the keypad acts like a remote, but I was curious if it keeps transmitting when you hold the 'enter' button long enough, or it cuts off after a couple of seconds. Usually it takes about 4 or 5 for car systems to start blinking fast. Guess we'll have to wait for somebody else to try it. He he.
. Yes, the keypad acts like a remote, but I was curious if it keeps transmitting when you hold the 'enter' button long enough, or it cuts off after a couple of seconds. Usually it takes about 4 or 5 for car systems to start blinking fast. Guess we'll have to wait for somebody else to try it. He he.When I paired with the remote, it only took 1-2 seconds to program it even with the rolling code, much faster than I expect.
This is the Canada and US version of W213 E class manual: https://www.mercedes-benz.ca/content...s_manuals.html
If you go to Page 149, 150, you should see some instructions for programming garage remote to the car.
