W213 Wagon Roof Rack
I almost thought that OE was OEM from Thule since the price is almost same ankr design in pictures looked the same
Thules low profile mount with their wing bar (aerodynamic profile) makes any load or roof box come closer to the roof greatly reducing wind noise.
If you are looking to transport bikes, ditch the roof rack idea and get a Stealth Hitch with a tray hitch rack. Much more convenient and safer.
If you are looking to transport bikes, ditch the roof rack idea and get a Stealth Hitch with a tray hitch rack. Much more convenient and safer."
I definitely like the idea of the hitch, but have a tandem as well as singles, so will still consider the bars..
I start my first rail behind the sunroof and the second one at least 70 cm behind it.
Anyway, you already solved the possible so good on you.
1. The bike racks I was using are the Yakima Front Loaders. The front mount is fixed, meaning the length of the bike rack starts where your front cross bar is. With a wagon it means there is a limit to how far your front crossbar is before the back of the bike rack tray hits the trunk door spoiler when it is fully open. You can also keep hitting the spoiler with your rear bike wheel when loading.
2. The sun roof - I wanted to be able to open the sunroof even with the bike racks attached. You start losing clearance with the clamps and bolts that hold your rack on the crossbars, depending on what type you are using. In my case it was the Yakima Universal MightyMount. I had to cut the bolts shorter so the open(ing) sun roof would not hit them.
You expect 20 minute relatively simple installation project, and it turns into a half-day 3 dimensional puzzle.
In any case, all First World problems.
