E-Class (W213) 2016 - 2023
Mounting and Balance?
Old Jan 26, 2018 | 10:13 AM
jhpmbusa's Avatar
2021 M550i
I have a 2018 E300 Sport. Its not really noticeable on regular roads (residential) but when i'm on nicely paved roads like the highways and parkways I feel a little judder/wobble - which I feel like its coming from the front right side of the car. I notice it more if there is a slight curve or so when leaning in...
I don't think its to the extent where the rim is bent nor do i think its alignment issue. Is it possible that It could be a balancing issue? or any other solutions/recommendations before I bring it into the dealership?
It is pretty minor and if a tech took it out for a spin I believe they would say there is nothing wrong with the car.... so I want to have a good story/case before heading in.
Old Jan 26, 2018 | 10:12 PM
Cao Black's Avatar
2015 ML350+2025 E350
A tire shop that sells your brand or your MB dealer should check that for you. Out of balance front tire is generally felt through the steering wheel, and may be more or less noticeable at different speeds. Rear tires out of balance are "felt" more through the seats. A tire flaw such as a sidewall bubble or even a broken belt inside the tire might give this sensation. Have the pros check it out. Tires (and rims for that matter) are pretty easy to sort out, so eliminate them before going further.
Old Jan 28, 2018 | 02:27 AM
cetialpha5's Avatar
Not sure if something like that would be covered under the bumper to bumper warranty. If it is, take it to the dealer. If not, just take it to a shop and have the tires balanced. When they balance it, they should be able to tell if the rims are bent or not. The BJ's wholesale club balances tires for $6 a tire so that's where I went last time.
Old Jan 30, 2018 | 04:42 PM
Long Islander's Avatar
2018 E400 4matic Wagon
If you're going to take the car to a tire shop, make sure they have a Hunter Road Force balancer. You can find a shop by visiting www.hunter.com. Almost all European brand car dealers have the Hunter Road Force balancer.
