E-Class (W213) 2016 - 2023
Wireless Charger Activates Apple Pay?
Old 06-02-2018, 10:28 AM
Sunrose305's Avatar
2017 E300 Sport
When I place my iPhone X on the wireless charging pad in the console of my E300 it activates the Apple Pay feature showing an image of my credit card and says "double-click to pay." No idea why. Has anyone else had this happen? Oh...and it also charges the phone.
sabrinatsmith (06-02-2021)
Old 06-02-2018, 11:20 AM
ua549's Avatar
Wireless charging has nothing to do with Apple Pay. It is the NFC signal emanating from the console lid. There are several threads about this issue. Do a search.
Sunrose305 (06-02-2018)
Old 06-03-2018, 12:58 PM
xrayted's Avatar
'17 E300 & '20 GLE 350
The iPhone has a NFC chip in it but Apple chooses to use that for it Apple Pay which is why you are seeing it pop up every time it gets near the signal.
Old 06-03-2018, 04:50 PM
78degrees's Avatar
2018 E63S
Just switch off NFC in the car and Apple Pay will not start again.
Old 06-05-2018, 06:29 PM
bellavance's Avatar
2018 E300 4Matic.
What's the use of NFC in the car anyway?
Old 06-06-2018, 08:49 AM
ua549's Avatar
NFC is used for connecting with a digital device being used as a key.
Old 06-06-2018, 08:59 AM
bellavance's Avatar
2018 E300 4Matic.
Digital Device being used as a Key.
Are such devices presently available?
Old 06-06-2018, 09:27 AM
LogicalApex's Avatar
2014 C300 Luxury
NFC can be used to make bluetooth pairing really easy be removing the "code sharing" step where you need to confirm that both devices are showing the same code. You can get a quick idea from the quick summary from Bose for their wireless headphones. Apple currently doesn't support this and only uses NFC for Apple Pay so it opens Apple Pay whenever it sees NFC.
https://www.bose.com/en_us/support/a...-nfc-qc35.html
Old 06-06-2018, 11:23 AM
ua549's Avatar
The device can be a smartphone or a tablet. Currently the "key" service is not available for US E Class models.
That said NFC is used to connect a smartphone to the entertainment system when the phone is placed on the charging pad.
During this year's CES, Mercedes-Benz announced that its new E-Class is enabled with capacitive aerial coupling. By simply placing the device on the charging area on the front part of the center console, the smartphone connects to the multimedia system via NFC. Moreover, while using NFC, the customer's smartphone becomes the digital vehicle key with which the car can be locked and unlocked as well as started.
Old 08-05-2018, 09:05 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Can anyone tell me where the setting to turn off NFC is in Comand settings?
Old 08-06-2018, 08:57 AM
ua549's Avatar
Go to System/Connectivity menu. Untick the NFC box.
Old 08-06-2018, 09:24 AM
rbrylaw's Avatar
Thanks. I'll give that a try later.
Old 08-06-2018, 10:38 AM
rbrylaw's Avatar
I just went to the garage and turned off the NFC chip in my car. Maybe it's not a big deal, but now when I place my iPhone in the charging cradle it just starts charging and for whatever reason, Car Play started faster as well!
Old 08-06-2018, 10:41 AM
Scott in H-town's Avatar
2005 E55
Is CarPlay wireless? My wife's SLC has to be plugged in via cable to use CarPlay otherwise it's just bluetooth streaming.
Old 08-06-2018, 10:42 AM
rbrylaw's Avatar
Unfortunately, Car Play is not wireless. I don't think there are many if any in the US that are. There's a USB plug next to the charging pad, specifically to connect the iPhone, via USB and Lightning Jack (you have to provide the chord) to activate Car Play.
Scott in H-town (08-06-2018)
Old 08-06-2018, 11:22 AM
2005 E55
Ok. I had read that some BMW's have it wireless now. If it's connected via wire, then the charging pad is redundant, right?
Old 08-06-2018, 11:39 AM
rbrylaw's Avatar
I'll have to check out whether the charging pad is redundant or not. Either way, it's nice to have a specific cubby to keep the phone in while driving. TBH, I don't really need my phone to charge while driving. My phone is charged at night while I sleep and the battery lasts me all day, often into two full days on a single charge.
Old 08-06-2018, 01:54 PM
ua549's Avatar
You must not use you iPhone very much. The most optimistic specs say 11.5 hours of video watching. Using the phone for voice and data consumes much more power. My sister-in-law has an iPhone X and has to charge it twice a day.
Old 08-06-2018, 02:01 PM
rbrylaw's Avatar
I use my phone all day. I don't stream video much, but I make and receive lots of calls for work and I stream Pandora a lot. Still, my battery lasts a loooooong time.
Old 08-06-2018, 08:31 PM
cte21's Avatar
2007 Subaru Legacy
Every MINI from 2018 forward has wireless CarPlay, and I believe the new 5-series does as well. I was hoping Mercedes would employ this as well.
Old 08-08-2018, 11:25 AM
rbrylaw's Avatar
Hey Scott,
I did look last night to see if the phone is plugged in and connected to Apple Car Play, if the phone is charging even if not on the charging pad and it actually is. So yes, plugged in for Apple Car Play, the charging mat is redundant.
Scott in H-town (08-08-2018)
Old 08-08-2018, 11:28 AM
2005 E55
Hey Scott,
That was my guess. Thank you for confirming!
What's nice is, you could actually charge your phone and another phone at the same time fairly easily.
Old 08-08-2018, 11:30 AM
rbrylaw's Avatar
Yes, you could actually charge up to 4 phones at the same time.
The charging mat
The USB for Apple Car Play
Two USB ports in the center console
And of course with an adapter, there is a 12v post in the back for your passengers, but you'd need a 12v to USB converter in there, which is easy enough to get.
Ps: what's the status on the E300 you're considering?
Old 08-08-2018, 02:30 PM
2005 E55
The charging mat
True!
As for me, I'm still looking. There's the blue one, but I found a 2018 (silver) with 6k miles for close to same price. It only lacks the panoramic roof and isn't my first choice in color, but silver never looks dirty, so there's that...
Then, my ADHD has me also looking at a E400 Coupe ... much more expensive, but WOW.
Old 08-08-2018, 02:33 PM
rbrylaw's Avatar
True!
I had a 2012 E350 Coupe for a couple years. It was nice, but the lack of 4 doors ultimately became a nuisance. I marvel at how they remove 2 doors and charge more for what is essentially the same car! I like the Panoramic Rood, but TBT, I don't open sunroofs all that often, so I'm not sure it would be that important an option to me. My new E400 did come with one however.
Happy E hunting!
Quick Reply: Wireless Charger Activates Apple Pay?
