E-Class (W213) 2016 - 2023
W213 Battery location
Old Jun 10, 2022 | 09:33 AM
Long Islander's Avatar
2018 E400 4matic Wagon
I have a 2018 E400 wagon and this car does indeed have one battery, located in the engine compartment on the passenger side. The battery is not visible. It is under the pollen filter. If you're planning on buying a new battery, I would suggest you buy an absorbed glass mat ("AGM") battery. Check the warranty on the new battery. In terms of size, the seller should be able to state which battery fits.
Old Jun 12, 2022 | 06:33 AM
TB!'s Avatar
TB!
S213
I just had the battery in my S213 All-Terrain replaced. It is an easy operation that doesn't require elaborated skills or special tools. However, I was warned by my mechanic that the new battery has to be trained. As I didn't want to evoke any electrical issues I had it replaced in the workshop. I chose a Bosch AGM 95 Ah (# 0 092 S5A 130) as it cost only 140 EUR. Most probably any AGM battery with sufficient capacity (> 80 Ah) will fit.
Old Jun 12, 2022 | 08:56 AM
chassis's Avatar
2017 GLE350 4MATIC
http://rk.mb-qr.com/en/213.0/
Old Sep 10, 2023 | 06:45 PM
DML756's Avatar
S55 AMG 03; '68 280SL, 2018 AMG E63s
very useful photo. But how is the pollen filter removed?
Old Sep 10, 2023 | 08:45 PM
chassis's Avatar
2017 GLE350 4MATIC
Old Sep 10, 2023 | 09:30 PM
DML756's Avatar
Thanks....great video.
Old Sep 10, 2023 | 11:06 PM
  #32
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Originally Posted by chassis
Thanks for posting. On youtube there are other videos that show basically the same thing.
Couple of points:
  • When you change the inside filter I believe you must work on your back. Setting the seat all the way back will give you more room.
  • The filter in the engine compartment is easy and straight forward. The inside one not so much.
  • Only the Germans could engineer changing a pollen filter, which is routine maintenance, in such a ridiculous manner. For example on my Ford, (made in the USA) the filter in the glove compartment takes less then 2 minutes to replace. Easy as 1,2 , 3.
Whoever engineered the replacement of the inside filter and anyone who approved it should be fired!
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
