E-Class (W213) 2016 - 2023
Door closing e300
Old Jul 24, 2018 | 01:10 PM
pmenger's Avatar
2006 carrera 2s couldnt wait for e63
Door closing e300
I have been smacked a number of times as the detent to hold the door open is insufficient. Service told me he’s heard this and there’s no fix. Anyone else.
Old Jul 24, 2018 | 01:47 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Check with your dealer about this: LI72.10-P-068218 JUN18 – 213 as of 4/16 up to/including 4/18 production, front doors can overrun detent points and close on uphill gradients, replace lower hinge.
Old Jul 24, 2018 | 01:48 PM
konigstiger's Avatar
'71 Pinto
Lower hinge may need replacement, see attached bulletin.
File Type: pdf
Old Jul 24, 2018 | 02:29 PM
Mbracer26's Avatar
Past 03 SL500,03 C240, 07 E350, 07 ML350, 10 ML350,11&14 E350 X2 2017 E300, 2017 C350e & 2000 S500
I dont see a updated part in this, what are they doing that fixes it? It only took them three years to get this right. what a shame.
Old Jul 24, 2018 | 02:35 PM
'71 Pinto
Bulletin lists modified part 2137201110 / 1210.
Old Jul 24, 2018 | 02:40 PM
Nsikan Essien's Avatar
2017 E-300 4 matic
Hey. I had the same issue in my 2017 E 300. Took it to the dealership last month. They ordered new hinges, sprayed it and installed for both front doors. All covered under warranty. It’s still not as good as I think it should be but it’s much better that it was before. Can’t tell you how frustrating it was getting out when parked in my driveway because of the slight slope. Got tired of backing in as well.
Old Jul 24, 2018 | 05:53 PM
etaynor's Avatar
Hi All,
I did all of the above. Had the dealer change the hinges. Very nice job. Worked better, but not perfectly. Lower hinge broke on the drivers side 3 weeks later. Dealer replaced it with e300 part, not the replacement(quick fix) part. Back to same problem, except i'm more careful how i open the door, and before i exit the car.
Old Jul 24, 2018 | 06:10 PM
Mbracer26's Avatar
Originally Posted by etaynor
Hi All,
Shouldn't matter how you open door, the hinge shouldn't break, these hinges are designed to withstand car accidents, that is not ok. Please make a report on NHTSA with your door closing in on you. This is the only way to get Mercedes to create a real remedy and possibly save a life.
