E-Class (W213) 2016 - 2023
Tire pressure confusion/conflict!
Old Jul 25, 2018 | 11:31 AM
amf77's Avatar
2018 Mercedes E300, 2015 Porsche Boxster S, 2012 Volvo S80 3.2
Hello. My 2018 W213 shows conflicting tire pressures. Tires are Pirelli P7 245/45 R18. The door jam states: cold pressure....37 front, 43 rear. The gas tank flap states: cold pressure...32 front and back for "normal" use, and 33 front/ 39 back for "Max" load.
I have been keeping cold pressure.....37 in front and 38 in the rear.....for normal use. Why is Mercedes "conflicted"?.........thanks!
Old Jul 25, 2018 | 12:20 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
Not conflicted, actually. Generally speaking the door jamb shows a pressure that would accommodate multiple tires. Since MB puts lot's of different tires on their cars, they don't create a door jamb that is specific to the tires that were put on your car. But the gas filler door sticker is for your specific tires and what you should use as your guide.
Old Jul 25, 2018 | 01:23 PM
ua549's Avatar
My 2018 E300 tire pressures are the same on the door jamb and the fuel door. What model is your W213? Is it 4Matic?
Old Jul 25, 2018 | 01:46 PM
rbrylaw's Avatar
That is not universal across all cars in the class.
Old Jul 25, 2018 | 02:05 PM
ua549's Avatar
You missed reading the fuel door instruction to add 4 pounds pressure for high speed driving. At full load the pressure matches the door jamb pressures of 37 & 43. Front is 33+4=37 and rear is 39+4=43.
Old Jul 25, 2018 | 02:33 PM
larrypmyers's Avatar
Veteran: Air Force
16 GLC 19 Volvo XC40 06Corvette Z06
Follow the tire pressure guidance located on the back of the fuel filler door.
