E-Class (W213) 2016 - 2023
What do you think is pretty useless / could be improved upon?
Old Aug 17, 2018 | 03:29 PM
  #51
tonecas's Avatar
skoda octavia MkII 2.0
Originally Posted by rbrylaw
Me too! If I get behind the wheel of any other car, I wind up turning on the windshield wipers as I've grown so accustomed to the MB Shifter on the stalk. It feels fine to me, but then I've had one now since 2016, so it's second nature after all this time.
same here! i always been used to have a lever on the right side for the windshield wipers and having now a gear lever at the same position is really awkward. there is currently a real mess with manufacturers trying to figure out new ways to place the gear sifter since with auto transmissions and the electronic stuff there is no need to have the sifter placed on the central column, so they are moving to steering wheel column levers, buttons on central column, dial buttons, etc. this actually has been cause of deaths because one needs to not have to think where to get the reverse or drive positions in stressful situations and the implementations are usually not intuitive. I wish MB had kept the sifter on the central column like a manual one, as BMW done with the new M5
Old Aug 17, 2018 | 03:33 PM
  #52
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
It doesn't bother me in the least where MB has located the shifter. It's second nature to me at this point.
Old Aug 17, 2018 | 05:30 PM
  #53
mickhoog's Avatar
W213 Night Edition 220d. (ML250 SLK350AMG)
Me too lol
Old Aug 18, 2018 | 12:04 AM
  #54
e400c's Avatar
2018 Mercedes-Benz E400 Coupe
Originally Posted by Cambridgehank
The analog clock, when there are two digital clocks in the displays.
It is redundant, but it gives another little touch of class to the interior. It also has a delightful easter egg in that when you cross to a different time zone, the analog clock adjusts itself automatically, and the dials move at an impressive speed to get to the new correct time. In my Infiniti G35 Coupe there was a nice analog clock and the digital clock from the retractable navigation screen. The digital one was GPS-synced, but the analog one wasn't. It's cool to have all clocks GPS-synced in the Mercedes.
Old Aug 19, 2018 | 02:41 AM
  #55
Tiburonsteve's Avatar
E300
3 things to improve in E class
1. The seat and mirror adjustments aren’t programmed to the car keys. You have to press the appropriate adjustment button and hold it in. My wife drives with the seat far forward so when I use the car, I have to stand outside pushing the button, in rain or shine, hot or freezing weather. Dumb.
2. There is no way to preview a navigation route—no navigation list view. You have no idea how the navigation is taking you to your destination. It’s the only navigation system I’ve seen without this feature. My $80 Tom Tom has it. Dumb.
3. The navigation system notifies you of a freeway exit or a turn 1/2 to 3/4 of a mile in advance. This cannot be adjusted by the user. If you are driving 60-70mph in the left lane of a mulit lane freeway, the exit warning is about 30-45 seconds in advance. It can be impossible (or dangerous) to cut over to the right lane in time to exit or turn. . Dumb.
I do like the gas mileage, comfort, ride and several other things. If only they would fix the above design problems.
Old Aug 19, 2018 | 01:11 PM
  #56
The_Judge's Avatar
2018 E400 Coupe
I tend to agree with you regarding your issues #2 & #3 (#1 not a problem for me as I'm the only driver of the car). My 2008 Cadillac CTS's NAV system was far superior on both counts, and there's no valid excuse for MB's poor execution of what has become a nearly essential feature of modern cars more than 10 years later.
However, with respect to #2 one workaround is to zoom out map, which is easy enough with the large knob on the center console. That's sufficient for me to get around the greater Los Angeles and Orange County area as I'm familiar enough with the freeway system to know then the computer has its head up its tailpipe. I also ignore 99% of the system's suggestions for alternate routes, which often would route me though very sketchy areas and crowded surface streets.
Given these very obvious problems, I have very little faith in other computer-based systems in newer cars. Most are simply not ready for prime time, IMHO,
Old Aug 19, 2018 | 04:28 PM
  #57
E300
Mercedes used to program the seats to each key. I think they stopped doing it for legal reasons—someone in the drivers seat getting squeezed when a key was pressed. It’s like McDonalds deciding to serve luke warm coffee to keep customers from burning themselves—make thousands of customers unhappy to avoid a possible legal problem. I’m an attorney but attorneys shouldn’t be in charge of such decisions.
I have used the map zooming workaround. But navigation should be most useful when you are completely unfamiliar with the area and you shouldn’t have to resort to workarounds in a car like this. I’ve owned seven Mercedes with several different navigation systems and not one of them was as good as the after market Garmin and Tom Tom systems which cost a fraction of the price. Mercedes needs to rethink who is running this aspect of their car design. Despite my past loyalty, I won’t buy another Mercedes unless they improve their electronics.
Old Aug 19, 2018 | 04:48 PM
  #58
tonecas's Avatar
if that was the reason it seems dumb. there are standard solutions to this, including already in use by MB. just have sensors detecting if there is someone there and if they are being squeeze. in (some) MB coupes when someone goes to the back seat and the front seat is automatically set to the front passenger and moves back and hits the legs of the back passenger it immediately stops. like it should with soft-close doors (and not whip-off fingers like it has happened in BMW) or with electronic side windows. just standard and well tested tecs that work if manufactures don't cut costs in building these components.
Old Aug 21, 2018 | 01:34 PM
  #59
rbrylaw's Avatar
Every car has it's quirks, so there's nothing perfect out there. Overall, I'm very happy with my E400. If there was one thing I would change, it would be the QI Charging mat and the location of the USB to power AppleCar Play. For one thing, the charging mat is TOO small. I don't even have a plus sized phone as I have an iPhone X, but in it's very slim case, it's not easy to lay it flat on the charging mat to get it to charge. Plugged for AppleCar Play, it's not possible for it lay down flat. And I'm planning on getting the new iPhone X Plus when it rolls out in a few weeks, which will render the charging mat to be useless. The other issue is where the USB port is located for AppleCar Play. It interferes with things you may keep in the cup holders. The execution of both the mat the USB weren't done very well IMHO. I know.......first world problems, right? LOL
Old Aug 21, 2018 | 02:06 PM
  #60
wagonsrock's Avatar
2018 E400S
Thats what I was told in Germany by the delivery specialist when I picked up the car in Sindelfingen. Of course, the person getting squeezed was an American ... Those sorts of issues are why the owners manual is so awful because it reads like it was written by lawyers - it was!
Old Oct 1, 2018 | 07:27 AM
  #61
Cambridgehank's Avatar
E400
Red face lights in cup holders?
We just finished a drive from VA to MA. My wife put a iPhone in one of the cup holders during the trip. As we removed the phone, red lights were shining . are there really lights in the cup holders?
Old Oct 1, 2018 | 09:22 AM
  #62
rbrylaw's Avatar
Yes, yes there are!
Old Aug 15, 2019 | 11:28 AM
  #63
Marc Kaplan's Avatar
2020 E450 Cabrio
Me too in my wife's X3. But I also dislike what BMW did with their shifter.
Old Aug 15, 2019 | 12:29 PM
  #64
rraisley's Avatar
2020 MB E450 Estate, 2019 Kia Niro Touring
That's disappointing to hear. I've had automatic remote driver position when opening keyless since 2006, and it's one of many things I would have expected on this car, which I have yet to order. So many simple little things, standard on much less expensive cars 15 years ago, yet not available here.
Old Aug 15, 2019 | 10:03 PM
  #65
whoover's Avatar
'19 E63S sedan
I was told they did away with it because it confused people. Too many service visits for "it no longer knows my seat setting." Another feature they did away with because people are morons was the motorized rear view mirror. In my S55 all three mirrors were on memory. But people didn't know how it worked and forced the rear view mirror into position by hand, stripping the mechanism. MB got tired of replacing them and did away with the feature.
I was also told you had to hold the memory button while the seat moved to prevent people from getting squashed. I was pleasantly surprised that they fixed that. On my '19, a single tap and release is all it takes.
Old Aug 16, 2019 | 01:37 AM
  #66
rraisley's Avatar
I'm hoping that MB owners aren't more stupid than the general population. As mentioned, our 2006 Toyota, of which I'm sure many more were sold than MB during that period, had the feature, and I guess we were just lucky, that no one got squashed.
Didn't know any cars had that, although I've been surprised none I knew of did. At least I won't miss it as never had it.
Did I understand from a previous post that the seat /will/ move to the position indicated on the remote if you press or hold a button on the remote, rather than just opening the door?
Old Nov 23, 2019 | 03:19 PM
  #67
baadmon's Avatar
2020 MB GLE 350
Parking Pilot. I have used it quite a few times, but it appears to struggle to locate open parking spaces as I pass them. At times, I've passed multiple open parking spaces and the car will just not recognize them. I even circled around just to see if the car would recognize them on a subsequent pass and it would not.
Old Nov 23, 2019 | 03:44 PM
  #68
The_Judge's Avatar
2018 E400 Coupe
Totally agree. I experimented with it when I first got my car and quickly concluded that (1) it passed up perfectly acceptable spaces because it deemed them too small and (2) it took about four times as long as I do to park the car in any given space. Big whoop.
Old Nov 23, 2019 | 06:46 PM
  #69
ua549's Avatar
Though I don't look for parking spaces, the parking pilot I use the 360° camera that is part of parking pilot many times a day.
