E-Class (W213) 2016 - 2023
Lights off?
Old Oct 25, 2018 | 08:02 AM
etaynor's Avatar
Lights off?
Hi, I have an e300 2017. I would like to know if there is a way that i can turn off all the lights around the outside, and the inside of the car, and still leave it running.
I like to sit in the car when i'm early for an appointment at night without all the lights on.
Thanks, in advance,
Old Oct 25, 2018 | 11:53 AM
rox's Avatar
rox
2018 E220d
Yes you can. Turn the light switch all the way to left. But once you turn off the car don't forget to put it back to ''Auto''.
Old Oct 25, 2018 | 03:45 PM
wagonsrock's Avatar
2018 E400S
On my US spec 2018 E400 this does not turn off all the exterior lights: the far left positions (there are two which are closer than rest of switch positions) turn on left or right parking lights. I have managed to 'trick' the system after turning the ignition off by opening the drivers door, as if I were getting out, and then closing it; after the usual exit delay all the lights go off.
Old Oct 25, 2018 | 03:48 PM
rbrylaw's Avatar
2019 E450 4Matic & 2018 E400 4Matic
You are correct. I'd wager a guess this is a DOT or NHTSA requirement that if it's dark and your car engine is running, lights are mandatory.
Old Oct 25, 2018 | 05:42 PM
rox's Avatar
rox
2018 E220d
In my case, engine has to be running. If you turn it off and leave light switch all the way on left side. Parking lights on left side are glowing.
Old Oct 29, 2018 | 02:12 PM
gfmohn's Avatar
2021 E450, 2020 C43, 2015 C300, 2007 C280
Same system in my MY 2015 C300. If the engine is running, some lights have to be lit. I ask, what took the feds so long? This important safety feature prevents those "ghost cars" you DON"T see at night (especially, if they are black)! What you can't do is turn your lights off and on to signal those other cars that are driving with their lights off. (I was following another car a few nights ago that had the tail lights out, although the headlights were working. I could only switch from "AUTO" headlights to running lights and back again."
Also, there have been several fatal accidents recently that were caused by wrong-way drivers on our local interstate highways. Some of them occurred late at night when the two cars were the only cars on the road. One asks, how could these happen on a three- or four-lane highway? Simple, the drunks steer for the lights of the oncoming car; it's all that they can see! I have tried to prepare myself mentally for such a situation. I would prefer to turn OFF all of my lights and steer for the breakdown lane. The best I can do with my Mercedes lights is turn my light switch all the way to the left (European standing lights on the left side only), as I steer for the breakdown lane. Then open the door and bail (telling any passengers to do the same).
Old Oct 29, 2018 | 02:40 PM
ua549's Avatar
I just experimented: the European standing lights on either the left or right do not function in my car. When either is selected, no exterior lights are visible. This is during daylight hours with the engine running and the transmission in drive. I'll try this again after sunset.
It works the same way at night. Just turn the light switch all the way to one of the 2 leftmost positions. In my other life before retirement I often sat in my car with all the lights doused and the engine running. It is a very useful feature.
Old Oct 30, 2018 | 01:48 PM
jumpman726's Avatar
2024 E350
It's not a DOT or NHTSA requirement. Other cars, including BMWs, have an OFF mode for the lights. I think Mercedes does not offer an OFF mode because they think too many Americans forget to turn their lights on, so they just have an AUTO mode.
Old Oct 5, 2021 | 12:44 PM
Chris Lamb2's Avatar
2007 s550
Thanks, in advance,
Its ok.. pharmaceutical rep we will call it, been there and understand completely. Those auto light settings suck at 3 am in some sketchy neighborhood
Old Oct 5, 2021 | 12:45 PM
2007 s550
Actually I think that's GPS that causes those kind of accidents because my ex. If the gps said make a left. A left was made whether it was the correct spot to make a left or not
