Run Flat Tire -- Experience
Yesterday, my wife took our E class, to the supermarket. On the way over, she called me and stated that the display on the dashboard shows a pictograph displaying the chassis and 4 tires. Illustrated was the tire pressure and tire temperature of all four tires. One of the rear tires showed pressure of 31 psi, and it was shown in red. Both front tires had originally been set to 37 psi and both back tires had originally been set to 39 psi. The rear tire, which had the puncture, was shown in red, and showed 31 psi. on the pictograph. I swapped cars with her and drove her car home. All during the 3 mile trip home, the tire pressure of the punctured tire stayed at 31 and 32 psi. (probably heat related variance) The point being is that when a run flat tire is punctured, it is still apparently safe to drive, and it doesn't ruin the tire, or the wheel. Bringing the car home, allowed me the opportunity for a look at the tire. I first checked tire pressure to confirm what I saw on the pictograph......confirmed. Then I jacked up the car and removed the wheel/tire. This is the heaviest wheel/tire I have had on a car.....so much for weight savings., It did work as designed though. I found where the puncture was, and marked the spot. (the puncture was very small, making me believe that the puncture could have happened some time in the past??). I then took the wheel/tire to a tire shop for repair. The tire shop repair procedure is the same as any other tire; ie. take the tire off the wheel and put a patch on the inside of the tire.
My concern is: if we we are on a trip somewhere, and we are in "timbuktu".....with a tire puncture and nothing nearby for repair......with no spare, what to do. (Fortunately, we belong to AAA and I guess they would come out and "plug" the tire?) (From what I have read, AAA is a better choice than the Mercedes assist button?).
I thought I would share this experience, as I am sure there are others who have not had experience with Mercedes (Pirelli) run flat tires. Hope this is helpful.
Or until we can have the tire looked at. Mercedes along with BMW will not simply plug the tire, they will replace it on inspection. I had to replace my tire once since purchasing my vehicle, and to be totally honest, I wasn't concerned one bit. At first, I was just going to have the tire plugged, then I remembered that I have the wheel & tire warranty. And they replaced it, no questions asked. So, if I was you, I wouldn't be overall concerned about this.
Run flats eliminate the spare which saves weight and increases fuel economy -imo, the main reason for the RF.
I drive to Vermont to ski and wonder what I would do if I got up in the morning and the tire was flat: Not a pretty story:
I am in southern Vermont, Ludlow. I had a BMW 535 iXdrive with RF tires. If I had a flat, I was told to call BMW service. The nearest dealer was in Burlington, VT 150 miles to the north. They would send a truck to flat bed my car and hopefully return it to me within two days. Even though there is a large Chevy dealer in Ludlow they did not carry RF. Ditto tire dealers in Rutland, some 40 miles away.
This problem was solved with my present 2016 E350 which has a spare.
Now the problem is back again with my E450:
Tire and wheel insurance only helps with payment!
Tire and wheel insurance does not help if you have to wait several days for a RF replacement!
With the 2019 BMW 540i xDrive you can order a spare. Unfortunately, Mercedes does not give you that option.
So if you get a flat in "smallville, USA" you are plain dumb out of luck! (and me too!)
Having a spare in your trunk when you go to "Smallville, USA" is nice insurance.
It is not just the weight of the tire, but the elimination of the wheel, jack, etc. all to save weight to increase EPA estimates. This more than offsets the additional weight of the RF vs. ordinary tires.
see: https://cars.usnews.com/cars-trucks/...-pros-and-cons
I suspect that they might just say buy a new tire as ordinary tiers are compatible with the wheels of run flat tires.
See: https://blog.tirerack.com/blog/bens-...at-wheelswheel and tire -
Here is another link to the the "pros and cons" of run flat tires: https://www.edmunds.com/driving-tips...-a-primer.html
Of course I do not know how that weight effects EPA gas ratings, but we do hear about manufacturers "Bragging" and making a big deal about using aluminum for example to save 100 lbs.
So savings 43 to 48 lbs. might be meaningful.
https://www.pirelli.com/tires/en-us/.../tire-warranty
I think in the old threads, there's a lot of hate for run flat tires, lots of people switch them out for regular tires as they feel they're smoother, quieter tires.
I'm not sure about Mercedes-Benz dealers but BMW dealers will not repair/plug a RF tire, they require you to purchase a new one.
