[W213 - 2018 E400 Sedan] Winter Wheel & Tire Package Options
First time poster, Please let me know if i am violation any of the forum rules. Thank You!
Would anybody be able to share any of their 2018 W213 Winter Wheel & Tire Package configurations? I am not familiar with the aftermarket options and any imformation is grealy appreciated.
Would love to learn about quality (OEM vs.aftermarket) and price of configuration (fees including getting wheels mounted, etc.)
Some of the options I am aware of are:
1.
Dealer package: 3,624.08 CAD
Dealer Wheels Only: $1,986.56 CAD
Dealer Rims Only:?
2.
Canadian Tire Tire Only: 1,775.96 CAD
Considering Rims (Good Brands but pricey) - are there any cheaper and still good quality rim brands?
Vossen
Vorsteiner
HRE
Thank You,
James Lin
EDIT: Merry Christmas!
I have a 2018 C238 and opted for a non-dealer configuration. I discussed with my local tire & wheel dealer and we both kinda concluded that running non-run flats would probably be suitable for me as I don't really drive the car much and considered less then 1/3 of the cost we put together a package which I am happy with. Since the MB customer assistance & warranty are still in effect and I already have a CAA membership towing would be covered in extraneous circumstances. From the experiences with run flats I read on this forum and others it appears that towing is needed in a high number of instances so I figured maybe better to have a tire which at least can be repaired by any shop as opposed to special order winter run flats which nobody have in stock except an MB dealers. MB dealers are pretty far apart north of the Toronto area. I have a air pump & repair kit which is tossed in the car also.
Tires:
https://tire.yokohama.ca/tires/bluearth-v905
Wheels I opted for a gunmetal colour rim with Mercedes blue logo.
https://www.replika.ca/productinfo.a...pe+(c238)_s_pp
When comparing the quality & durability of aftermarket wheels to OEM wheels the aftermarket wheels will typically always be better than the OEM wheels. The biggest reason for this is that auto manufacturers need to maximize profits on the cars they sell. An easy way they save money is to make a wheel using the low pressure casting method for manufacturing. It is the cheapest way to produce wheels but the final outcome is a wheel that weights a lot & isn't very durable.
Vorsteiner has a Flow Forged series and HRE has a FlowForm series. The manufacturing techniques for these wheels is a step above the low pressure casting method. These wheels provides you with a lightweight wheel and a wheel that will last you the entire duration of owning the car.
We have a 20% off on HRE FF04's & 30% off on HRE FF01's until January 2nd. This puts both wheels near the $2k USD mark for the set or under. Contact me if you're interested in learning more David@WheelsBoutique.com.
You can go down an inch or two in wheel size and increase the tire height for more tread depth.
You need to figure out the wheel offset to clear your caliper. I’m sure you could look around here or PM a person in a wheel post to find that out.
In US I would recommend Tirerack.com.
OR
You could go over to a local rim shop and buy the wheels/rims from there. Your going to need to get them installed wether online bought or from a shop.
Lastly, it sounds like this would be your first car to do this for. Your probably better off going to a local rim shop rather then doing the online buying unless you are 100% your getting the right configuration.
If you don’t get the fit right, you can end up with off Toe/Camber which would defeat the purpose of getting snow tires and result in worse traction.
