Hi there. I got a E220 estate September 2017 (W213) which has been basically fine. On occasions it locked up when I was driving and I took it back. The first time they replaced a sensor but it did it again so I took it back in. They say that the sensors were set to go off from too far away and there is no fault with the car. They also say that if it happens again I would have to demonstrate it to a technician. So I have a car which has locked up when I am passing an articulated lorry at 60mph and it is my fault! Surely this is dangerous to have too sensitive sensors in the car or am I missing something?
2012 merc amg
close
- Join DateJul 2013
- LocationVenice Florida
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive2018 S560
Liked:773 Times in 594 Posts
There is a setting for Sensitivity of this under the Assistance settings. I just leave mine in the middle under medium and have had no issues.
Quote:
Thanks for replying. The owner’s manual says that the brakes should only lock at the same time as the audible warning under “exceptional driving circumstances” but this has happened 5 times in normal conditions. My wife won’t drive it. Originally Posted by 2012 merc amg
nycebo
close
- Join DateNov 2014
- LocationNew York, NY
- Vehicle(s) I drive2021 Mercedes Benz e450 Wagon
Liked:76 Times in 57 Posts
I had this issue as well. I changed it to "early" and have not had the issue since.
That’s interesting. I have found that when the car has been passing another car, lorry or object on the left side of the car, this is when the car has locked up. It seems to me that taking the settings away fro “early” is just hiding a fault in that the sensor is too sensitive and is dangerous.
Quote:
Agreed. I'm inclined to think there's a dodgy sensor in play here.Originally Posted by David Alcorn
It might be that in your country, the passing and driving style triggers the sensors to believe your going to crash but in reality your not. In America, we have big roads, besides actually going to crash, the sensors won’t throw a false brake.
Quote:
Funny you should say that as the one on the passenger side was replaced when it was in in August. Every time the braking has been activated it has been when something was in my left hand side. Never on the right. Originally Posted by stephos
I’m not sure what driving style won’t trigger, but. I don’t have much confidence in a garage that just checks if there’s a fault (they say there isn’t) then changes the settings of brake assist to the late or close setting and tells me it’s fine. Surely if it is fine, they could leave the car on any setting?
I'm going in on Monday morning to have a drive with a diagnostic technician (I presume that’s a mechanic) so I will maybe find out more then.
Stick to your guns on this one David. The dealer needs to isolate the problem and fix it.
If they can't or wont, then try another dealer.
The problem you describe is quite dangerous for you and others potentially. Totally not acceptable.
