To runflat or not to runflat... That is the question.
The jolting and large thunks while driving up my driveway has gone away.
On a very smooth road the 20's were quiet - however AK and I live in Australia where smooth roads only exist outside politicians houses.
I use only nonruflats (pilot sport 4s) and they work perfectly. Stickiest tire on the market. There is even an MO version.
Obviously, these companies think you should use RF. They have their reasons, whatever they are. Maybe they are right? But, I'll stick with Non-RF simply because I would like to be able to deal with a bad tire at ANY local shop on-the-spot. And with some luck, right on the road where a flat happens (although that has never been the case yet).
But it's strange about tires these days. The same dealers that sell you car with RF also sell you cars with 18" and 19" wheels, which is another thing I have a problem with, right along side the RF craze. This I'm certain I don't like and frankly do not get. It's bit hard to wrap my mind around the fact they would virtually ruin a luxury's car ride for cosmetics. And don't tell me it's for performance as they put them on SUVs and every car.
So the take-away is I don't trust anyone when it comes to wheels
Of course if you are on the road with a non RF and have a bad leak you must pull over and change your tire, assuming you have a spare in the trunk or wait for road side assistance. With a RF you can also wait for roadside assistance or drive to a tire dealer: two options instead of one.
Several years ago in Consumer Reports they downgraded the RAV4 Limited because the Limited went to 20" wheels vs. the standard 18" wheel. CU stated that their was a noticeable decrease in the quality of the ride. They highly recommended the normal RAV4 but did not recommend the Limited because of the ride.
Tremendous improvement has been made in the ride quality of RF over the past 10 years. Today's cars suspension are specifically engineered for RF. Manufacturers work with tire manufacturers in the design of RF for their cars.
The marginal ride benefit, if any, between non RF and RF, is negated by the advantages of RF in the event of tire leak. The only real advantage of non RF to RF is the price.
But if you "immediately replaced the run flats to non run flats" as you did on your S Class, while there were still thousands of miles of tread life left on the original RF, then of course there is no savings only an added expense.
Even parking and hitting a curb, may cause damage to the those 20" wheels.
That being said, if you can see potholes, best to avoid them. 2 Months ago there was a stranded W163 ML with 255/65r16 wheels on our country roads with cracked front rim due to a nasty deep pothole in southern Victoria. Glad I got the warning in Waze ahead of time to slow down and avoid the hole.
Since you're in New England and have to deal with winter affected roads, I'd think you cant go wrong with Michelin Primacy Tour A/S for the best elasticity on tires. Also do note Michelin is going to release Primacy 4+ in 2022 rumoured to promise longer tread life with the same comfort levels.
