Dumping RFTs — A Cautionary Tale
I knew I was taking a risk as the car has no spare, but I figured (1) I'm older than dirt and not about to change my own tire under any circumstances, and (2) I have AAA and roadside assistance coverage on my auto insurance and my AmEx, Visa, and M/C credit cards. Besides, I've had only a couple of flats in 50+ plus years of driving except for three about 10 years ago, all on a set of Continentals that seemed prone to picking up nails and screws (dumped those for Michelins — no problems after that). So I figured that rolling the dice was a good bet.
But as Bobby Burns so aptly put it,
Gang aft agley,
An' lea'e us nought but grief an' pain,
For promis'd joy!
On April 23 I had business at a community college in Santa Clarita, about 45 miles from my home in Hermosa Beach, CA. When I returned to my car and began to drive out of the lot, the dash lit up in red letters, "Check Tire Pressure." I did and the sensor indicated that the right-rear tire was down to 16 pounds. My first thought was that the TPMS for that wheel had gone crazy as the was no obvious problem with the tire, so I drove to a gas station about a mile away and checked the tire with my gauge, which showed that it was indeed very low. I pumped up the tire to about its normal PSI of 35, which I verified with both my tire gauge and the TPMS. I felt all around the tire but found no problems, so I kicked into full paranoid mode and thought maybe one of the students had messed with my tire. I decided to drive slowly to the tire shop near my home from which I had purchased the new tires (which had a little less than 400 miles on them at that point).
It soon became apparent that the TPMS wasn't the problem as the warning again popped up on the dash. I checked the pressure again and the computer showed that it was down to 20 PSI. I pulled off the freeway at the first opportunity, found another gas station, and again filled the tire. After that I kept the tire pressure displayed on the dash, watching it slowly dissipate as I drove. I had to make two more stops for air, the last one only 1½ miles from the tire shop.
The shop pulled the tire to inspect it and found the puncture, which had made by a piece of fairly thick sheet metal (i.e., thicker than a tin can, maybe 1/16" thick) about 3/4" long, 1/2" wide, and shaped like the blade of a box cutter or X-Acto knife, sharply pointed but without a sharpened edge. The piece of metal was in the very middle of the tire tread, sticking straight in, point first, and had been worn down and was not sticking above the tread itself. Very odd, so maybe it was vandalism (but probably just my bad luck). In any event, the shop removed the metal, patched the hole, and remounted the tire on the car. So far it's holding air.
Despite all of this, I'm still not interested in getting a spare, in part because of the room it would take up in the trunk and because there ain't no way I'm going to change it myself should I have another flat. I did, however, buy a compact 12-volt tire pump to keep in the trunk along with a can of Fix-A-Flat (I know, I know) in case I'm in a spot where I can't reach AAA, etc. But I'm not considering going back to RFTs. Yet. 😉
Here's Tire Rack's rating of the 4S tires, which handle great, ride very nicely, and give me good feedback:
Gang aft agley,
For promis'd joy!
https://www.homedepot.com/p/RYOBI-18...P737/206159256
When I owned a Audi A8L I had it in for service. I noticed in the parts department several flats of new tires - between 40 and 80 new tires. Clearly marked on each flat was "TIRE RACK".
So to answer your question, ua549 is 100% correct: there is no difference exempt in the price you will pay!
With that being said, I tend not to spec MO tires as the PS4S for my E63S4S are wider in the non-OE specification.
Suspension/ shock absorbtion is primarily the tires' job. My experience (in northeast) is that all the little tar lines, patches, scrubbier pavement, etc. don't really transmit all the way to the suspension with a nice soft walled NRFT. They do more with RFT's. These small shocks are not enough force to use/activate/compress the car's suspension, so end up traveling thru it.
When I hit bigger "suspension" bumps (vs. "tire" bumps) it's clear what they are- my mind doesn't expect the car to go over it smoothly- so maybe I slow down a bit or something unconsciously or just accept it more unconsciously. (Or rather, it's clearly not unconscious in my case,
)It's the taught suspension/ soft tire combination that for me gives the best feel of that "stick to the road", planted feeling. (As a side note, the road bike world has been doing similar things with ever stiffer forks/chainstays, but preferring bigger, softer tires at lower pressures- even discovering that rolling resistance and efficiency don't suffer, while rider fatigue can be improved. Different is that this also actually decreases the likelihood of flats, because of more air volume in the tire, so less chance of a rim/sharp edge "snakebite" puncture. Less of a concern that object punctures in most cars.)
On perfectly smooth pavement I can't tell a difference. On bigger bumpier roads, I know it's a bump so don't expect the car to be completely smooth regardless (on a bike I'd lift out of the saddle just a bit to let my legs absorb the shock.) It's that in between stuff that I feel like is 95% of roads/my time in the car that I prefer the NRFT's for. I suppose it's also true that my cycling gives me a habit of looking at pavement closely.
Admittedly, I have not tried all RFT's and hope they are improving. However, for my personal preferences - theoretically (without a very different cross section profile) I don't see how they can or will make a sidewall both stiff enough to run flat for long enough, but resilient enough to absorb the small bumps at speed when not flat. Puncture resistance has gotten so good regardless my risk calculation has both a low probability and low consequence. It's been a long time since I have had a true flat, and I'm good with a fix a flat or wait for roadside where I live.
Selected Tire Manufacturer's Policies for Run-Flat Tire Repair
The following list summarizes tire manufacturers' run-flat tire repair policies, however it should be noted that every tire manufacturer that consents to repair, does so only after the punctured tire has passed a thorough exterior and interior examination.Manufacturer/BrandRepair PolicyAdditional Provisions
BFGoodrichPermitted1 repair maximum
BridgestonePermittedOnly if 15 psi maintained
ContinentalDoes not recommendMfg. Road Hazard Program*
DunlopPermitted1 repair maximum for H- and greater speed ratings
FirestonePermittedOnly if 15 psi maintained
GoodyearPermitted1 repair maximum for H- and greater speed ratings
HankookPermitted
KumhoPermitted
MichelinPermitted1 repair maximum
PirelliNot endorsedMfg. Road Hazard Program**
YokohamaNot to be repaired if run-flat
*Replaced free of charge first year or first 2/32" of wear (whichever comes first). Continental advises that a repair to one of its tires invalidates all other manufacturer's warranties.
**Replaced free of charge first year or first 2/32" of wear (whichever comes first), then prorated until worn to 2/32" of remaining tread depth.
Tire manufacturers' policies for non run-flat tire repair can be found here: Flat Tire Repairs' Effect on Speed Rating
Use of run-flat tires deemed non-repairable may result in vehicle or property damage, as well as can cause personal injury or death.
Tire Rack will not repair any run-flat tires that have been driven in a severely underinflated or zero pressure condition because the service conditions they experienced and integrity of their internal structure cannot be confirmed.
HankookPermitted
KumhoPermitted
https://www.michelinman.com/US/en/tires/warranty.html
https://www.continentaltire.com/warranty
https://www.goodyear.com/en-US/tire-.../30-day-pledge
I have around 12 months left on my lease so might be lucky. Also will keep the 2 run flats and replace back before returning the lease.
