Alternative to Run Flats?
I have been following this post because I have Pirelli P7 Cinturato RF tires - all season. Have had the car for 6 months and totally satisfied with the ride, handling and even snow conditions. The ride is excellent and they are quiet!
I am in the North East so a summer tire like the Judge put on his car, Michelin Pilot Sport 4S is not a viable option.
I previously posted about a spare in the well of my E450 - but does non fit there. I do not want to give up my trunk space for a spare.
I also decided against run flat sealant as if used you must replace the TPMS system and sometimes the wheel as well if you do not clean the wheel quickly.
As a stop gap I have a high quality battery operated air pump in the well of my trunk. Other than a sidewall blowout, I should be able to keep the tire sufficiently inflated, so as not to damage the sidewalls, to get it to a garage where the flat can be fixed.
In another post, the P7 allow for one flat to be fixed.
So I am interested in the self sealing tires and if anyone has experience with them, like the OP, I would love to hear from them.
One final thought: if you lease, as I do, when you return your car, you must have similar tires: i.e., if the car came with Run Flats, at lease end you must have Run Flats as well.
As JTK44 suggests, a good 12V airpump for top offs is a good idea. I keep one in my trunk, along with a cheap Wallyworld tire plug kit, in case the tire leaks down too far overnight. Just pull the nail, rasp out the hole, and feed a rubber plug slathered in kit sealant provided, and it's as good as a tire seller repair, IMO. Replenish the air pressure with the pump and you're in business. I've gotten so good with this that often I can plug a flat with the tire on the car. And my plugs hold for years afterwards.
I do NOT like the idea of tire sealant that messes up the TPMS sensor, or settles in one spot inside the tire once you park for a while (balance issues).
1) It's a Sat/Sun morning and I'm not going to work,
2) I'm in the garage for other business and discover a tire leak-down, meaning I have the time to play,
3) I plan to do some other task that will soil my shirt or jeans later, and elect to fix the tire first
4) the flat is on a rear tire, and...
5) the source of the puncture is in plain sight facing out the garage door where I can get to it easily,
6) I feel inclined to get on my knees/back, etc.
I'd had two knee replacements in the last 8 months, so tire work on my knees/back are no longer in the cards.
