Hi all, long story but came out the store to this. Confirmed with Mercedes that part https://parts.mbofwilmington.com/oem...ens-0999067101 will work for replacement.
Has anyone ever replaced these? The dealer quoted me 150 for the part + labor, wondering if I can do it myself since it doesn't seem impossible. The paint is another issue smh....I've had so much bad luck with this car (not Mercedes fault just with people hitting me).
Very easy job, you don't even have to remove the glass.
Just pull the housing forward from the top using your fingers then the indicator comes out after loosening two screws.
