Better door locks?
3. Follow this procedure:
Here is the trick that the MB master mechanic told me (and I can confirm that you need to do it this way). Connect both the door pin and clip together and then lock the door, next push the door pin/clip combo down as far as it goes... it will lock in place. If you attempt to screw down the black clip and then push the door pin over it (as designed), it will stick up too high.
https://mbworld.org/forums/c43-amg-c...hese-look.html
I tried to use the trick Vic posted but has hard as I pushed, they didnt go down
099-766-27-00
Button F Locking Sys
$1.76
4
$7.04
099-766-01-00-2A17
Lock Knob
$8.00
4
$32.00
I'll update once its installed!
099-766-27-00
$1.76
4
$7.04
099-766-01-00-2A17
Lock Knob
$8.00
4
$32.00
But anyways I got my eyes on: 099-766-01-00-2A17 and 099-766-27-00.
Let me know how this works out for you, and if you have some installation vids/pics that'll be really helpful
Also, can you show some pics of when it's locked and unlocked?
Thanks again!
Thanks again!
It just keeps the lock pin set to the proper orientation since if you bottom out on the threading it most likely won't line up the AMG lettering.
Also the plastic pin set feels cheap and they don't hold on tight. Not that you would but if you ever tried to manually pull the pin up the cover would just fall off in your hand. It's cheap as hell. But it also sits below the lock hole when locked so you can't manually remove it and it looks stupid. It should be flush. I'll be buying the overpriced AMG ones I guess.
