A four cylinder engine ?
Back to the 4 cylinder. While it is not the new inline 6 in the GLE 450 or the X5 drivetrain, I have found the 2.0 litre in the GLE to be more than adequate. This is a completely new engine ( as I understand) compared to the 4 in the E300. With the 9 speed auto, it accelerates as well or better than her 2016 3.5 NA V6. There is minimal turbo lag and low end torque is good. Passing on the highway at speeds between 65-80 do not cause undue stress. Engine noise is not the smooth whir of an inline 6 but (at least in the 2020 GLE) it is well muted and not bothersome. The car only has 1000 miles so it has not been beaten on but it does the job without needing foot to the floor abuse. C and D just tested the GLE 350 and got a 0-60 time of 6.6 seconds. Extrapolate the weight drop for an E350 and you should be seeing high 5s or 6 seconds for 0-60. But really it is about feel and given how decent the GLE 350 feels with the extra 6-700 pounds, I am guessing it will make a fine duo with the E Class chassis. And by the way, her current, unbroken in vehicle gets far better mileage then the previous two.
As an aside, I am of the age when I remember that the fastest Camaro you could get in 1982 (when I got my license to drive) could go from 0-60 in 9.5 seconds. Today base Camrys and Accords can do 0-60 in 7-8 seconds which was muscle care acceleration in the 1970s and better than most muscle cars until power starting moving up in the later 1980s. We have all become so spoiled by today's cars that we scoff at cars that do 6 second 0-60 times from puny 2.0 litre fours. For perspective, the 1976 Cadillac Eldorado was rated at 190 horsepower from 8.2 litres.
When I ordered my 540, the 530 is still using the older version of the 4 as compared to the one in the new 3 series so I did not consider it even though it accelerates to 60 in the low 6's. Had it had the upgraded 4 from the new 3 series (and in a few years they will all be at least a mild hybrid like the new GLE 450) , I would have definitely considered the 4 without hesitation. So yes, for 3 years I will delight in my very quick, buttery smooth inline 6. But next time I will try out the 4 and likely get the 4 and a few more options.
Good luck with your decision. I think that unless you are a true leadfoot you will find the E350 to be a more than adequate and very nice luxury vehicle.
The dealership definitely prided itself on being a First Class shopping experience including offering to let me take a car for a spin on the spot. I would've if I had more time. I'm not sure where they get their salesmen, my guy's english was impeccable -- I thought I was listening to a BBC newsreader. I told the guy I wanted info regarding the E350 and he showed me Mercedes official numbers of 0-62 in 6.3 seconds (or roughly 6.0 seconds to 60). The horsepower figures were slightly different though - 258 BHP instead of 255 here in the US. I asked if I could keep the brochure but I managed to leave it in my hotel when I left for the airport. So much for that.
All E350s and 450s get the full digital screens and in order to get heated seats the salesman said it often requires special order since most of the vehicles in their inventory had cooled seats instead. I sat in one to make sure and would you believe the switch on the door was for cooling only? I forgot to ask if rear cooled seats were an option.
So it appears that the "new" engine is modestly faster, and noticeably more fuel efficient than the 2.0 liter which preceded it. Not sure why the MBUSA site doesn't list this info though.
You can get a copy of the brochure here:
http://www.auto-brochures.com/mercedes_benz.html
E300:
241 hp @ 5,500 rpm
273 lb-ft @ 1,300–4,000 rpm
E350:
255 hp @ 5,800 rpm
273 lb-ft @ 1,800–4,000 rpm
But the 0-60 mph went from 6.2 seconds in the E300 to 5.8 seconds in the E350 (RWD)
interestingly the 2020 E350 4MATIC is 5.6 seconds. Faster than the RWD. Traction helps with that 0-60. Although the 2017 model the RWD was faster.
sources:
https://www.mbusa.com/content/dam/mb...***-Family.pdf
https://www.mbusa.com/content/dam/mb...PDF_101719.pdf
