E-Class (W213) 2016 - 2023
2019 E450 - Make ECO mode the default
Old Dec 9, 2019 | 01:52 AM
vinnybenz's Avatar
2013 GLK350 2016 GLE400 2019 E450 Wagon 2018 S560 2021 E450 AT
I know that about 99% of you folks would prefer to shut off ECO mode entirely but I was wondering if there is a way to make the ECO mode the default as opposed to the Comfort mode.
Thank you
Old Dec 9, 2019 | 02:36 AM
JDPEClassUK's Avatar
E Class Estate S213
Don’t think so. The issue of setting Sport as default has been discussed many times with the conclusion that it always defaults to Comfort.
Old Dec 9, 2019 | 02:53 AM
whoover's Avatar
'19 E63S sedan
Thank you
There are third-party modules to do this.
https://www.ebay.com/itm/MERCEDES-Dy...3/263510156531
Old Dec 9, 2019 | 01:37 PM
The_Judge's Avatar
2018 E400 Coupe
Thank you
Don't confuse the ECO setting for the transmission with the ECO setting that shuts off the engine every time the car comes to a stop. It's the latter that many of us dislike and have taken steps to defeat, but I don't believe it has anything to do with the transmission's ECO mode.
Old Dec 9, 2019 | 05:13 PM
whoover's Avatar
'19 E63S sedan
The E63 doesn't have an ECO transmission setting. I guess that's to make room for the RACE setting. I'm not sure what the difference is between ECO and COMFORT, which in the E63 makes everything mild. But we do have INDIVIDUAL, which can be tailored but defaults to everything the same as COMFORT. But even though C and I look to be identically set, they're different. I, but not C, allows "sailboat" or coasting mode, which seamlessly disconnects the drivetrain when no power is needed, such as when on a gentle downslope. (It is smart enough to keep the engine connected if the grade is steep enough for engine braking to be advisable.)
I'm either in I (for ultimate fuel economy) or S+ (for ultimate performance) most of the time. They really should offer a course in Dynamic Select.
Old Sep 22, 2022 | 01:04 PM
midcityeng's Avatar
PREMIUM SPONSOR
2013 SL550, 2016 GLE350, 2016 GLC300
Our ECO213 installed solution allows you to have the vehicle start up in individual mode each time.
Check it out here: https://www.midcityengineering.com/product/eco213/
Old Sep 22, 2022 | 04:47 PM
CarFan1's Avatar
Porsche Cayman S, Mercedes W213, Nissan Titan, BMW X5, Chevrolet Suburban
I have the 2018 version of this module installed on my W213 and I love it. You can pick your default setting and the auto start/stop mode is turned on manually, instead of automatically. I had the module installed at a truck accessories shop and I assume that it is simple enough to install that you could go any place.
Now when I want sport, I turn it on and the same when I want eco mode.
