E-Class (W213) 2016 - 2023
A warning to those buying a certified Mercedes
Old Jan 17, 2020 | 02:21 PM
cetialpha5's Avatar
Originally Posted by Camaroguy72
here’s the link to the one without sport brakes
https://rover.ebay.com/rover/0/0/0?m...2F152672222467
you can also get the lifetime warranty ones from Fcpeuro
I priced out the rotors on fcp + akebono front pads and oem rear pads plus bowa sensors (oem supplier ) and it comes to $680 and you get a lifetime warranty from fcpeuro
I've used the Zimmerman rotors and those were fine. You don't need the extra sensors as the pads come with them and there is only two, one for the front and one for the back. Also you can reuse the old ones if the light isn't on. Once they're worn through, the light comes on. If they're not worn through, you can just reuse them. I'd also do Akebono pads for the rear also. I have them on both cars, never really have to clean the wheels because there's minimum dust. But you'll get a ton with OEM pads. So you'll get front wheels with no dust and rear wheels covered in dust.
Old Jan 17, 2020 | 02:44 PM
ua549's Avatar
I get almost no dust with my '18 E300 w/AMG upgraded (sport) brakes.
Old Jan 17, 2020 | 04:19 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Mercedes Benz of Pittsburgh sort of burned me here. Bought a CPO 2015 MB E400 w/27K miles and had it shipped to me because I was basically in the hospital for a couple of months. It had a pretty bad ding on the rear bumper, the front fascia was all scratched up and it had a completely hosed front passenger side wheel bearing. Otherwise, it's a great car, but I expected it to have had those things corrected and fixed prior to delivery. I know, my bad for buying sight unseen... I'm still planning on eviscerating them on their online reviews. Damn yinzers.
Old Jan 17, 2020 | 06:25 PM
Jan AMG's Avatar
The best or nothing
I have bought several CPO cars throughout the years and all had issues that a sensible dealer should've had fixed. However, if technical, all these issues were fixable under $1,000 USD per car + figuring out what's wrong so plenty of time obviously and if cosmetic, you cannot expect a flawless used car and almost anything cosmetic can be fixed and made even nicer than new (usually non OEM respray and parts alignment is better).
The last dealer was kind and offered me a $900 USD discount (without me asking) and replaced brake pads at their expense before the pick up.
Old Jan 18, 2020 | 07:53 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
I recently purchased a CPO 2016 W212. I feel like I got lucky here in comparison. I had an extended test drive in a gray 2016 w/MB-Tex and static LED lights 24k miles. I purchased a 2016 w/leather and the lighting package as well as designo paint for $2,000 more with similar miles. I received a work order with the car showing what was done during the CPO process. The car was delivered with new front brakes/rotors, 4 new Continental OE tires, a replaced sun visor, and an alignment. We found that the parking brake would not release and there was a bit of abnormal wear on both the steering wheel and the weather stripping, and there was a very, very small nick on the back of the driver headrest. They repaired the leather wheel and even the pin-head sized nick on the headrest and replaced the weather stripping on all four doors as well as replacing the parking brake mechanism.
All in all, this seems like the proper experience.
Old Jan 18, 2020 | 09:26 PM
BeachBunny's Avatar
2018 E300 Luxury - P3 and more
Originally Posted by Richbot
The good news for me, at least, is my home dealer's service department is top notch, and I have an OEM-backed warranty, on a very costly car to fix, until 2023. In the pre-purchase regard BMW does a better job,
Coming from driving Infinitis for 20 years, the MBUSA dealership system is the wild west. Infiniti was very consistent from dealership to dealership. They even all used the same computer systems, run by Infiniti. With MBUSA, your local dealer may provide service worse than the local Kia dealership, but MBUSA doesn't care. If you can find a dealership with an excellent service department, MBs are great to have. Otherwise, run away. I drive past multiple dealerships to go to one with an excellent service department. Seeing the cars there (especially commercial), I'm not alone.
