This is my first time joining and writing in a forum. Can anyone help me with my steering wheel adjustment... It will extend out, but I can’t get it to tilt up or down. Is this an easy fix?
If by chance you’re referring to Easy entry/exit see activation. If not working at all should be covered by warranty most likely motor assembly, here is a view of your column. Also read this thread: https://mbworld.org/forums/e-class-w...t-working.html
2017 E300
I’m having the same issue and it’s the 3rd or 4th time now. I will schedule to get it repaired but not an emergency in this pandemic
Mine is a 2015. I had it repaired while under warranty that lasted for 1-2 years. Now it's doing it again. I'm using the bang the fist method UP and moving the switch. Sometimes that method does the trick, other times not. But, it will start moving again in the auto mode.
Dealership said it needed lubrication. I think it's more than that -- another "best or nothing" design from M-B. Right now it's working again for weeks.
2017 E300
Happened to me. Bang on the top of the column as hard as you can. It'll eventually go down and up again but. very slowly. I suggest you turn off the easy entry feature once you replace it so it doesn't break again and you're stuck fixing it on your own dime.
