E-Class (W213) 2016 - 2023
E400 vs E43
Old Aug 20, 2020 | 09:09 AM
stormhammer's Avatar
2017 Ford Mustang GT350
E400 vs E43
Apologies if this has been addressed, but from what I am able to find, the main difference ( aside from aesthetics ) is the E43 has a different tune, and a sportier suspension.
Reason why I ask is, I'm looking at picking up an E400 wagon, and would enjoy making it into an E43 AMG clone of sorts ( the tune, wheels, etc )
Old Aug 20, 2020 | 11:35 AM
Becksan's Avatar
2018 E43
Performance wise I think the E43 got different turbos - I have been trying to research the same, my concern is just the limitations on the gearbox (torque) - I haven't been able to find any actual numbers as I am contemplating a 400 vs 450. If only the US would get the E43 wagons....
Old Aug 20, 2020 | 03:15 PM
Yeah I've found the information on the turbos as well.
I believe the trans is still the same?
Old Aug 21, 2020 | 10:03 AM
Flash Gordon's Avatar
2003 E500, 2004 G35X
Racechip sells a chip E400 with very easy hookup for a few hundred dollars, will bump up hp significantly. You can also easily disconnected it. It does not modify ECU. Check it out.
Old Aug 23, 2020 | 10:35 PM
DubVBenz's Avatar
W212 M276 DELA 30 ; W211 M113k, W126 M117, W126 OM617, W211 OM642 ; R107 M117 X2, Sierra 1500 LZ0
Same turbos, different ECU tune. You can look this up via part numbers.
