E-Class (W213) 2016 - 2023
Button on dash.
Old Oct 14, 2020 | 01:53 PM
Stefko's Avatar
220d
Button on dash.
Hello dear friends.
Why does this button light up every time I turn on the car? Then after about 10 minutes of driving, it goes out.
It's never been on before.
I read that it is heat for the cabin.
But I have not turned it on.
And when I come, it's still cold in the cabin.
What is its function actually?
Because it's not something I turn on myself.
Old Oct 15, 2020 | 01:17 PM
Egonvdv's Avatar
EQE SUV AMG-line 350+
i don't have this but i googled it and it seems to be this:
https://moba.i.daimler.com/markets/e...a31-en-GB.html
however if i understand correctly, if it's on when you enter the car, it means that the heating has been programmed (?)
see also
https://moba.i.daimler.com/markets/e...a97-en-GB.html
Old Oct 15, 2020 | 02:00 PM
sillen963's Avatar
S213 E250 2017
That is the Auxilary/Parking heater, you can start it by pushing the button or programing a time in the menu the remote (accessorie) or by the Me-app on your phone.
It starts automaticly in low temperatures to heat the car/cabin quicker.
Old Oct 15, 2020 | 03:03 PM
Stefko's Avatar
220d
Thanks for the help.
Yes I have understood that it is parking heaters.
But what I find strange is that it always lights up when I start the car. Eventhough I myself have not put it on.
Should it do that?
I do not want it to drain the battery.
Old Oct 15, 2020 | 03:16 PM
konigstiger's Avatar
'71 Pinto
Have you checked settings.
Old Oct 15, 2020 | 03:38 PM
Stefko's Avatar
220d
Yes I have.
I have no timer on in the cars command nor in my mercedes me app.
It is disable.
I really do not understand why the button is lighting up every time I turn on the car.
Here in Sweden it is currently 7 degrees.
/Steven.
Old Oct 15, 2020 | 03:51 PM
'71 Pinto
What does MB Sweden have to say, BTW is vehicle still under warranty?
Old Oct 15, 2020 | 05:28 PM
Stefko's Avatar
220d
I have not been to my Mercedes dealer. I Will go to service soon, maybe i can ask there.
It has never done so before, it started doing so now that it's a little colder outside.
That's why I first wanted to check here on the forum if it's not usually so.
Yes I have a warranty left.
Old Oct 15, 2020 | 05:37 PM
Stefko's Avatar
220d
So you mean it starts automatically even if I have not turned it on.
Because I have it disabled and have no timer set.
Just think it's weird that it should be on every time I turn on the car, because then the fans are already on when I drive away. So whats the point? It will just drain the battery?
Old Oct 17, 2020 | 05:14 AM
sillen963's Avatar
S213 E250 2017
Yes! Jag tror den starar för att värma upp både motorn och kupen snabbare. Min började också starta typ förra veckan nu när det blivit kyligare!
Har du en diesel så behövs den också då sådana avger mindre spillvärme.
Den ska inte starta om batteriet är dåligt och bilen varnar då också.
Annars för du åka på reserven så startar den inte
MVH
Erik
Old Oct 17, 2020 | 06:12 AM
JakeW213's Avatar
W213 220d from 2016
I don’t have this button... I do have another button there that says SYNC - what does this one do then?
Old Oct 17, 2020 | 07:34 AM
Cao Black's Avatar
2015 ML350+2025 E350
With "SYNC" on, both driver and passenger zones are unified. Same setting apply to both zones. With it off, each controls their own zone.
Is the Stationary Heating / Stationary Ventilation feature even available on US cars? I've never seen it.
Old Oct 17, 2020 | 09:17 AM
JTK44's Avatar
2019 E 450, 2016 E350 4matic (retired), 2018 Ford Edge Sport, 2008 Porsche Boxster
Not on my 2019 E450
Old Oct 17, 2020 | 12:51 PM
Stefko's Avatar
220d
MVH
Erik
Ja precis!
Den har nu börjat att lysa varje gång jag startar bilen för att sedan efter ca 10 minuters körning försvinna.
Det jag tycker är konstigt och jag undrar över vad är vad den har för funktion då? Bilen är ju redan igång och blir varm av fläktarna. Och ja jag har en diesel 😊
Så du menar att den börjar lysa hos dig också? Varje gång du tänder bilen när det är kallt? För att sedan släckas?
Mvh
Stefan.
Old Oct 18, 2020 | 05:35 AM
JakeW213's Avatar
W213 220d from 2016
Why don’t you guys keep it english? Alot of people that don’t understand Swedish read these threads and can use the info.
ps. I understand Swedish just fine;-)
Old Oct 18, 2020 | 05:53 AM
'71 Pinto
So your question may be answered and makes sense coinciding with colder temperatures, easily confirmed when you’re in for service soon.
Old Oct 18, 2020 | 06:25 AM
Stefko's Avatar
220d
Yes, I can ask them when I'm in for service.
Thanks for the help everyone!
ps: I thought everyone understood Swedish! ))
