2017 E300 Auxiliary Battery (Voltage Converter?)
Hi all,
I have a 2017 E300 (delivery date in late July of 2016) so it's out of warranty. I have an Auxiliary Battery Malfunction light that appears about every 10 seconds. I've looked up as much as I can about this issue online, and from what I've seen for the 2017 E300 the auxiliary battery is under the passenger footrest area, have to remove the glove box bottom cover, pull back carpeting, and it's in that area (to the left of where the charcoal air filter is). And it's not a typical small battery like a motorcycle battery. Apparently, this auxiliary battery is called a voltage converter. Or also called a capacitor. That's what I've gathered from the research I've done online for this. The owners manual is not helpful on this topic at all.
My question is, does anyone know the exact part number for this auxiliary battery for the 2017 E300?
The Main battery is 001 982 81 08
Does anyone know the official part number for the Auxiliary Battery for my 2017 E300? (Delivered late July 2016).
Thank you so much!
Thank you so much!
Received 4,003 Likes
2017 GLE350 4MATIC
Please post your VIN.
Received 4,446 Likes
'71 Pinto
Your VIN has no auxiliary battery but rather a voltage converter (located passenger side foot well) original part # 2059052809, current 2059053414 also see here: https://xenons4u.co.uk/blog/mercedes...ion-explained/
chassis (11-01-2020)
Hi, I've tried to search those part numbers. It looks like they are superseded?
The one I found is: P/N: 205905341480
Can you look up in your system and see if that also checks out okay for the '17 E300?
Thank you so much!
Thank you so much!
'71 Pinto
205905341480 is correct only available as re-conditioned, last two digits 80 = reconditioned.
w211 320 sport
Today I did a preventive replacement of the capacitors. the producers give them 4 years estimated life. I guess on the 5th they run or dry out from the temperature. purchased similar from panasonic and simple replacement
chassis (07-24-2022)
