E-Class (W213) 2016 - 2023
Mercedes w213 Ambient Light doesn't work properly
Old Mar 15, 2024 | 05:25 AM
Ariz Kahn's Avatar
W205
W213 ambient lights brightness stuck on 8%
Originally Posted by Raul92
I'm trying to give an answer here so that we don't look for another answer if this resolution of mine is beneficial to others.
I had the same problem and I started looking on the internet without realizing that I had changed the pollen filter. What I mean is that when you change the pollen filter on the right side of the driver, the plastic that will have to be disassembled will be 2 threadsOne is for the temperature sensor (the warm air that will circulate the car) and a second for the light under the feet. When disconnected it will turn off the lighting under the feet of both front passengers and half the lighting on the driver's side (as in the presentations above, It is seen that even the ambient light does not work at the feet anymore) Try to see if these 2 contacts are well put back in place, to me that was the problem and I would not have realized if I had not changed my pollen filter myself.
It is possible that sometimes after service B or A (when replacing air filters) some "craftsmen" forget to put back the two wires Excuse me if I made mistakes in expression
Hello all,
I have w213 ..2018 model . Upgraded small screen and NTG5 host to wide screen digital and host to 5.5... Audio 20
Two problems.
Ambient lights change color but brightness only goes upto 8% then turns off .
Error :
Communication with one or several color generation and coupling modules on Lin Bus 7 is faulty
2nd issue .isnavigation sd card not reading
Can any one help
Thank you in advance
Old Mar 27, 2024 | 01:22 PM
MNIAW's Avatar
2017 M-B E400 4Matic Wagon AMG-Line
Another confirmation that this is the easy fix. My 2017 E400 wagon had the exact symptoms in your picture. When I dropped the plastic cover, my heart sunk a bit because it appeared that the wire was connected. I pushed on the connector and heard/felt a click. Voila, the lights worked as they should. The connector was not seated properly.
Thanks!
Old Mar 28, 2024 | 02:36 PM
Ultraman's Avatar
2019 E450 Coupe 4Matic; 2018 Audi Q5; 2019 Toyota Corolla Hatchback
Originally Posted by Singapore 2023
excalty, the light wire did not install back after changing the air cabin filter
Back to this old thread, are we talking about the white color connector that connected to the footwell lamp?
I had my car replaced the cabin filter last September. I did not notice the footwell lamp that was not "on" until today.
I removed the under dash cover and found out the wire was disconnected. I searched everywhere under the dash and I could not find the connector.
My car is the C238 coupe and the plastic panel is extremely hard to remove under dash (actually do not know how to remove)
I am taking it back to the garage which replaced the cabin filter and let them figure out where is the connector.
My driver side ambient light does not work as well.
Old Mar 28, 2024 | 03:38 PM
MNIAW's Avatar
Yes, the white connector. It is not easy to spot where it goes and the cover is difficult to work with. As I recall, the connector plugs into a raised black plastic "hump" just about in the center of the panel.
Old Mar 28, 2024 | 04:02 PM
Ultraman's Avatar
I just spent 30 minutes remove the plastic panel and searched the connector for the footwell light and I finally found it behind the carpet. The guy from the garage forgot to plug it back.
I connected the connector to the footwell lamp and everything was back to normal now.
So, in the future if someone has this similar problem, check the footwell light connector first especially after the replacement of the cabin filter.
Thanks to the one who mentioned about the light connector in this thread.
Old Mar 30, 2024 | 07:30 PM
Ultraman's Avatar
Hi Guys,
Do the ambient lights even turn "ON" during daytime? How do you set them to turn the ambient lights automatically on when there is not enough lights outside?
Old Sep 26, 2024 | 03:22 PM
  #32
Eclassw213tech's Avatar
Managed to fix it
FIXED THIS ISSUE !
So like others, my ambient lights stopped working all but the drivers door. I was very confused.
Simply fixed by replacing the fuse 468 in the fuse box located in the boot on the right hand side. The fuse *** is covered by a carpeted panel tnear the boot swing arm.
There is a paper leaflet with a full diagram in there and it shows you which fuse is which.
The fuse is a 7.5a nano fuse. I didnt have any to hand so I used another 7.5a fuse which controlled thw Parktronic system. Weirdly, the park tronic still works even though I swapped the 2. So I dont know if removing it fixed it, or swapping it fixed it. Fact is, its all sorted
Old Sep 26, 2024 | 03:23 PM
  #33
Also changing the 468 fuse in the boot worked for me.
Old Sep 26, 2024 | 10:10 PM
  #34
L1Wolf's Avatar
Veteran: Army
W214 E450
So you don't know if the fuse was bad? Did you test it or visually inspect it to see if the connection is broken? It's possible it just needed to be reseated. You should switch them back to see if it still works.
Old Dec 17, 2024 | 11:30 AM
  #35
BavariaBenz's Avatar
E400d
Fuse Nr. 417 reset ambient light controller
FIXED THIS ISSUE !
I had the same error last week (only ambient light at drivers door works, all the rest dark, E400d S213, 2019).
After I tried all the tricks I found in some forums I checked fuse No 417 in the trunk. My multimeter told me that it was fine but I pulled it out anywhy. Afterwards even the ambient light at the drivers door switches off. when I replaced the fuse 417 and started ignition all the ambient lighting was restored! So basically I think the controller crashed or was stuck in a undefinded status and it needs only to powercycle (what wasn‘t the case while the car is locked and parked for 24 hours).
I hope this helps somebody not to burn a lot of money for a new LED Controller or whatever…
greetings
Old Oct 16, 2025 | 09:50 PM
  #36
DKNYC's Avatar
2021 E350
Same thing happened in my car, dealer said it was a faulty ambient light under the wood panel, once they replaced it, it completes the circuit and all the lights work again including the footwell, costs 1600 USD.
Old Oct 16, 2025 | 10:14 PM
  #37
smiles201's Avatar
2023 E 450 Sedan. 2018 GLC 300. 2013 E 350 Coupe (retired)
Great price for a new bulb!
Old Oct 17, 2025 | 07:16 AM
  #38
DKNYC's Avatar
2021 E350
yes what can you do though, its not that bad, most of it was the labor, and i dont have the time or the patience to do it myself.
Offers a 2 year warranty so if it happens again i just bring it back and they fix it again.
Old Oct 17, 2025 | 08:22 AM
  #39
smiles201's Avatar
No way it took them that long to figure it out and do the work. If they have to replace within two years, I assume you get the bulb free, and again have the pleasure of paying 4 hours labor for thirty minutes of work.
Old Oct 17, 2025 | 08:56 AM
  #40
DKNYC's Avatar
2021 E350
Understood, but again not much more i can do and just prefer spending the money and picking up the car fixed, if i have more problems will just get a new S class next and the 4 year warranty on the car. Got a great deal when i ordered the car as well, MSRP was 66k and bought for 55K, now you cant get a new E350 with the same options for less than 80k.
Old Nov 8, 2025 | 02:03 PM
  #41
PGKG's Avatar
E400 Wagon
Ambient light near steering wheel and front passenger well light fix
My local MB dealer installed new cabin air filter (passenger side foot well) but did not reconnect wire harness. I noticed issue because LED ambient light under steering wheel area and the regular white light in passenger side foot well wasn’t on. Sure enough, I reconnected and problems solved. Hope this helps others.
Old Nov 8, 2025 | 05:08 PM
  #42
DKNYC's Avatar
2021 E350
Sounds like there could be multiple causes, to everyone's point though highly recommend after EVERY service, to check and make sure ambient lighting is working before you leave dealer or shop.
Old Feb 8, 2026 | 04:44 PM
  #43
MercMikeNL's Avatar
C238 premium
Had the same problem after a service B. They installed the cabin filter and just shoved the connector back in but not secured it. Footwell light was off and so was the ambient lighting right and left of the steering wheel. Once connected properly everything was back on. Didn’t bother to go back to the dealer…
