Battery drain
edit - my fob is always within 10 - 15 feet of the car most of the time.
I bought my W212 E-Class with Keyless GO in March, 2018. I can now tell you that I have not had to replace the battery in the fob
-- for the last THREE YEARS --
...because I keep both fobs in my Master Bedroom, about 75 feet from the car in the garage. The back-up fob has been stored deactivated in a bedroom drawer the entire time. My primary (activated) key fob sits on the dresser top, next to my wallet, etc. The car sits in my garage, unlocked. Did I mention it's been 3 years........?
MBz-Master's video illustrates what I've maintained all along but people choose to ignore... that the key within range of the car makes the car query to establish (or deny) a handshake. The handshake is NOT initiated when you touch the door handle.
Even if you maintain that the new fob goes asleep after minutes, then there is no real need for 2-click deactivation. Yet it remains, hmmmmm.... If you are replacing fob batteries every few months and leave the fob in the car or nearby, then you know that the fob really doesn't sleep (completely).
I have two keys both in range of my E450. If I double click, the smart feature was not disabled.
But if I moved key #2 out of range, and then double clicked the key #1, next to the car, the smart feature for that key #1 was disabled.
However, with the smart feature "disabled" by key #1, when I went to the car with Key #2, the smart feature was not disabled.
My conclusion: to disable the smart key feature and put your car to sleep, both keys must be out of range when you double click.
In the video, with both keys within range, double clicking would not have disable the smart key feature.
But if you are in parking lot, double clicking your key would disable the smart key feature, assuming your second key is not in the car!
If that is the case, then if you leave your Mercedes in an airport parking lot for 10 days to 2 weeks, when you return there is high probability that with all the attempted "hand shakes" your battery will be dead.
If this is the case is there a work around?
This implies that the car is "awake" to receive signals, too. Which means if you always keep an activated fob within range of the car, the car will not trully go to sleep, either, draining the battery (both fob and car battery) as in the video example. Both MBs I've owned have some power going to the clock and the small fan in the inside rear-view mirror housing, the alarm system, other functions? etc. So the car is never completely dormant.
Once again, we've drifted afield from the intent of the original post. But really, it seems that all these issues are related at some point.
But in any case, you're mixing apples and oranges. The most recent discussion is about whether the car's battery will drain in an airport parking lot because of the proximity of other fobs. These are different discussions.
But there is more! The SmartKey actually keeps looking for a car... even if the car is not within a range. The SmartKey looks for your car tirelessly and constantly. The only good thing when your SmartKey is not within reach of your car - is your car stops the communication and can go to sleep. That's why the Smartkey battery has to be replaced a lot more often than the regular key, and you should keep it away from your car.
Interestingly, the "handshake" is the first line of defense against the Relay theft, and if the handshake didn't happen - then the car won't unlock... even if you approach the car with the right key from your car. The Keyless Go won't work. That's why the relay attacks won't work unless there was a 2-stage authentication, which is not the case on older cars, by the way.
The 2nd stage of communication is when you approach your car very close and touch the door handle; only then (when all the planets are aligned) the doors will unlock.
On the latest models, there is a 3rd stage. The car will not start... unless the SmartKey is communicating from the inside of the car's interior. The SmartKey keeps the communication even when the vehicle is started and driven. Try to remove your key outside the car while it's running, and the car will show a warning immediately: "Key is not recognized". Relay Attack won't work either, because even if you unlock the door - you won't be able to start it since the keyfob is not present inside the car.
All of the above was designed against the huge number of easy thefts, especially widespread in Europe.
The latest Mercedes and BMW SmartKeys (from 2019 -2020) are now equipped with a motion sensor - to solve some problems. If you lay the key and don't touch it - it will go to sleep after a few minutes until you move it again, which is a relief. But the problem - this sensor is so small, it can easily be activated, for example, by wind, AC blowing, someone walking by, or if someone moves a drawer.
The only way to stop communication with your car is by double-clicking the lock button.
Quick parasitic current measurement with car off after a few minutes only indicated a 10-20 mA draw, totally normal. Hooked up a DMM capable of recording and let it run for 5 hrs with car off and locked. Sure enough after 4 hrs there was a spike to 5 A indicating a something awoke (module/s). Spoke with a friend who indicating there's CAN monitoring function built into vehicle and it can be read with Xentry.
Sure enough, in Xentry we were able to see the interior CAN was active (not normal). This car already had the HERMES software updated and main battery replaced... all which started after mouse damage to engine harness that was replaced by dealer.
In this case, the car will need to go back to dealer and have a CAN bus recorder installed. The recorder logs all activity and is used to further diagnose why certain modules may be waking up. Definitely a complicated issue and unfortunately a lot of time to figure out.
P.S. Everyone should get a Faraday cage keyfob holder anyway.
