Battery drain
for the past month there has been a parasitic drain it has been in and out of the dealership but it still keeps draining and its unable to start.
Its temperamental and happens at random times. I have tried checking how much power fuses are drawing and all of them seem okay.
has anyone got any suggestions?
Second: When you park your car make sure the doors are locked. This cuts down on the drain.
Third: If the battery is good have you considered a trickle charge? There are several threads on trickle charges. The consensus and what I use are chargers made by CTEK:
see: https://smartercharger.com/
Mercedes replaced the battery about 3 weeks ago.
All doors are locked
I will take a look at the trickle charger although the car was pulling between 8-10amps when it was completely off so it was just draining the battery in 4 hours.
I would suggest you take it back to the dealer: there is something wrong. If it is still under warranty have them fix it.
It just seems to be random times so im wondering if its a control module that seems to be pulling power at random times
I keep my car in the garage and drive it almost daily so like you, I do not have issues with the battery.
Check other threads and they describe in greater detail the advantages to battery drain by locking the vehicle.
Obviously, something changed. Happy that I saved myself a couple of hundred dollars.
Keep in mind that standby mode turns off the alarm.
I’m thinking of buying an MB. Looking at the forums, I’m surprised how many times I’ve seen “I have a problem and dealer can’t fix”.
As to problems: Very few of us post that we "have no problems": what you get on a forum are people seeking help with their cars.
The one exception: poor ride: but almost 100% of those with a complaint do not have standard wheels. I have standard wheels with RF and I have no problems with the ride.
