Programmed a few features in my 213. See picutres
This is for option 866. Allows you to download the comand touch app from Euro Apple store and control features from back of vehicle using ipad.
Intelligent Headlamps. Must code both headlamps also.
This feature allows you to control the back and bottom cushion temperatures.
I believe this is standard on newer E class cars but mine did not have it active. Setting these "moods" controls the scent, led lighting, seat temperature, and massaging.
This feature lets your car sleep for a long time. Perfect for long trips away from home to prevent the battery from dying.
Intelligent lights need "special" programming but authorizing a new device does not. Neither does standby mode that I use whenever I leave my car at the airport.
Here is a link to the Android apk of COMAND Touch.
Will it work with apple carplay? Like moving the media wheel in carplay(like its possible both from media wheel and touchbutton on steering wheel)
it will work, sort of with apple carplay, in that sense that the mouse part(will work as the dial) will move anything that is on the screen. But things like volume level cannot be changed(if f.x. Your are using spotify)
so its more a gimmick than actual usable.... only use I can see is if you have a rear seat passenger that you would want to control stuff - e.g if your using your car as an Uber Black or in a limousine service
I am not going to use it again
