E-Class (W213) 2016 - 2023
2018 e300 Road Noise?
Old Jul 4, 2021 | 08:38 PM
newmember2021's Avatar
2018 e300
I recently bought a 2018 Mercedes e300 that I generally love. However, the road noise is almost shocking for a luxury sedan of this caliber. It is not much more quiet than my son’s 2003 Toyota Matrix. Having conversations in my e300 are difficult on the freeway. I had the car checked out just after I bought it, and Mercedes said it was in great shape.
So I am wondering if there are some settings changes I can make that would make it more quiet? I have experimented with different ride modes, to no avail.
Has anyone else noticed this? I assume I’m just going to have to live with it until I can upgrade to an S class, but if anyone has any suggestions I would sure appreciate it.
Old Jul 4, 2021 | 09:00 PM
ua549's Avatar
Get some quiet tires! My '18 E300 is much quieter since I replaced the original RFTs with standard Pirelli Cinturato P7's.
Old Jul 4, 2021 | 09:04 PM
evd22's Avatar
E350d
It doesn't sound normal even for cars without the better, thicker glasses. I would start with looking at these two things.
1) Could be rubber seals around the doors need replacing/repositioning: there should be some other threads related to this, the noise may seem to come from a specific area, e.g. the b-pillar.
2) Crappy tyres put on by the previous owner: check whether the tyres are MO or MOE, and even among them Dunlop are worse than others.
Old Jul 4, 2021 | 10:21 PM
2018 e300
Thanks, I will check this out!
Old Jul 4, 2021 | 10:32 PM
evd22's Avatar
E350d
Originally Posted by newmember2021
Thanks, I will check this out! Which tire is better...MO or MOE?
MO refers to Mercedes Original, meaning tyres designed for Mercedes cars; MOE refers to Mercedes Original Extended, meaning run-flat tyres designed for Mercedes. Using MO or MOE depends on your preferences, most new Mercedes come with MOE. To some the sacrifice of run-flat (heavier weight, stiff sidewall, crappy ride, loud noises) is simply too much, but I love the assurance that I will always get to my destinations on time despite small punctures, which is quite rare these days anyway.
Also, a Pirelli P-zero tyre may be branded MOE, but you can also get just the Pirelli P-zero without the MOE label and it will be the same tyre and experience.
Old Jul 4, 2021 | 10:35 PM
2018 e300
Thank you very much for the info! I am new to Mercedes obviously. Absolutely love everything about the car, except this one issue. Let's hope some new tires will help!
