E-Class (W213) 2016 - 2023
Rear Sunshade Button Stopped Working
Old Aug 23, 2021 | 09:46 PM
joshg1001's Avatar
2017 E300
I know its not the physical sunshade that is broken because for the past year, I have noticed that the button on the center console would not activate to close or open the sunshade, but then will work again randomly after restarting the car. Now it has completely stopped working for the past week. Any ideas or easy things to check? Car is out of warranty.
Old Aug 23, 2021 | 09:56 PM
bmwpowere36m3's Avatar
'11 E350, '11 E550, '98 M3, '95 E320
Scanner
Since these aren't simple 12V switches, you need to verify whether the appropriate module is "seeing" the switch input. Then proceed accordingly. About all you can check is fuses and wiring integrity. People love checkign them... rarely are they an issue. Personally I'd invest the resources into an appropriate scanner as it'll be beneficial in the future.
Old Sep 7, 2021 | 02:41 PM
konigstiger's Avatar
'71 Pinto
Worst case scenario rear SAM or shade motor may be intermittently malfunctioning. As suggested always best to pull codes but not sure any will be stored in this case. Here is wiring to check shade & rear SAM if so inclined to do so.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 9, 2021 | 12:49 PM
joshg1001's Avatar
2017 E300
thats for that detail, probably not something I would tackle myself. Oddly, it started working again....
Old Nov 9, 2025 | 12:18 PM
6speeddave's Avatar
MB
@joshg1001, did this issue ever return for you? I am witnessing the same in my 18 E43.
Old Nov 9, 2025 | 12:44 PM
E300-18's Avatar
2018 E-300 4matic Sedan
Do you guys actually use that feature? When I first looked at the car, the salesman said that its purpose is, "In case you have weird people in your back seat."
I haven't messed with it since.
