E-Class (W213) 2016 - 2023
Overly Sensitive Key Fob?
Old Nov 26, 2021 | 12:49 PM
W205C43PFL's Avatar
Originally Posted by Longroof45
Well, I tried deactivating the fob by hitting "lock" twice but unfortunately the hatch still opens as soon as I hit the hatch unlock button (i.e., no 2-step process required). You are correct, however, that it should be a lot harder to accidentally trigger the hatch opening, because it really does require that you push and hold the button before it raises. Obviously, some other key or object must have pressed the hatch unlock button continuously while in some tight pocket for the hatch to open up accidentally. I think that from now on, when parking in my garage I will just check my MercedesMe Connect app to confirm all doors are closed and locked before I open the garage door. If it has been accidentally raised again, I can close it using the key fob. It seems like a lot of trouble but I guess in the scheme of things it's not such a big deal.
Since you are worried about your car's battery, I don't recommend constantly checking Mercedes Me. However, I do recommend using a faraday bag or box and also remove the battery of your spare key incase that one is triggering the unlock/release within your house.
Old Nov 26, 2021 | 01:01 PM
Longroof45's Avatar
2021 E450 All Terrain Wagon
Thanks, W205. That's a good idea. And when you mentioned spare key, a light bulb went off and it occurred to me that maybe it's not MY key fob causing the problem. My wife who hardly ever drives the car carries the spare fob in her purse which, of course, also houses a host of other things that women carry in their purses. It's probably more likely something in that purse is pressing on a key fob. I will buy two faraday pouches!
Old Nov 26, 2021 | 01:07 PM
W205C43PFL's Avatar
No problem and great job, glad you found the cause!
Longroof45's Avatar
Blame it on the wife lol.
Old Nov 26, 2021 | 01:22 PM
W205C43PFL's Avatar
Old Nov 26, 2021 | 02:42 PM
Diesel Benz's Avatar
I saw this on a UK forum:
Old Nov 26, 2021 | 02:47 PM
  #32
W205C43PFL's Avatar
https://youtu.be/r4FxWYebnFg
Well, I mean I guess that is one way to do it. Thanks for sharing.
Old Nov 26, 2021 | 02:50 PM
  #33
superswiss's Avatar
2019 C63CS
The easier way would be for your wife to leave the fob at home if she rarely drives the car anyway. She'll just run down the battery of the fob this way, and then the fob might be dead when she actually does need to drive.
Old Nov 26, 2021 | 02:53 PM
  #34
W205C43PFL's Avatar
Another great idea.
Old Nov 26, 2021 | 05:12 PM
  #35
Longroof45's Avatar
Thank you for the link!
Old Nov 28, 2021 | 11:20 AM
  #36
Longroof45's Avatar
Thanks, that's a good point. However, my wife often stays in the car while I pop into a shop or something, leaving the car in Park. She tells me that if she doesn't have her key her (and I have taken mine with me), the engine cuts off and/or she gets a repeated warning tone. When I return to the car I find a disgruntled wife and an open car door. I know this is really a First World problem but I think I'll give the faraday pouch a try lol.
Old Nov 28, 2021 | 11:27 AM
  #37
W205C43PFL's Avatar
Maybe switch position, you stay in the vehicle while your wife pop into a shop or something instead. Problem solved : ) Just kidding... hmmm or maybe not.
You could also bring your wife with you while you pop into a shop or something.
Old Nov 28, 2021 | 11:31 AM
  #38
W205C43PFL's Avatar
I got another idea, tell your wife to take out the battery of the spare key. If your wife wants to start the engine, consider just placing the key in the marked spot to disable the immobilizer. That marked space is precisely used for starting an engine when a key fob battery is completely dead.
Old Nov 28, 2021 | 11:46 AM
  #39
superswiss's Avatar
2019 C63CS
That would indicate your wife's key gets detected first and used to start the engine. Does she get in the car before you? Keep in mind if you put your wife's key in a Faraday pouch it will be shielded from the car, so she will get the beep and the engine cuts off. She would then have to take her key out of the pouch and restart the engine, which means she has to move over to the driver seat in order to push the brake pedal. Seems a lot easier if you just leave your key in the car if you run in the store leaving her behind.
Old Nov 28, 2021 | 12:16 PM
  #40
Longroof45's Avatar
😂Ha, you don't know my wife. I'm the chauffeur, she's Miss Daisy lol.
Old Nov 28, 2021 | 12:20 PM
  #41
Longroof45's Avatar
I am usually gently reminded that I'd better leave my key in the car😄. Yes, she often gets to the car ahead of me when I go to open the gates. I appreciate everyone's suggestions and good humor. I'm making a mountain out of a mole hill. I'm old enough to remember when I had to stick a key in the door and then stick it in the ignition.
Old Nov 28, 2021 | 12:46 PM
  #42
W205C43PFL's Avatar
Hmmm, in that case I guess you can tell your wife to leave the spare key home and then for you, remember the following: Leave key out then put face mask on. Or just write key! on the mask so when you grab it, you remember about it.
Edit: I guess the opposite can be done. Place key in the vehicle before you start to leave from your house then take off the face mask. Make it a habit just like wearing the face mask during the pandemic.
Old Nov 28, 2021 | 12:52 PM
  #43
Longroof45's Avatar
Old Nov 28, 2021 | 03:50 PM
  #44
W205C43PFL's Avatar
Don't stress too much about it just decide on a method that makes your life easier and go from there : )
