2017 e300 coolant temp sensor....I think?
According to the manual it could be the coolant temp sensor, low coolant levels or a malfunctioning fan. I know it's not the fluid level because I topped it up, the fan is work, so I ordered a temp sensor this morning. Doing my due diligence I wanted to find some info on how to change it. I can't even find where it is on the engine. Anyone got any suggestions on where it is? Or a link to pics/videos of where it is??
**EDIT**
Not sure if it makes a difference but the temps in AZ just took a nose dive and this seemed to coincide with that timing wise. Not sure if that makes a difference or not.
Thanks!!!!
The dealer couldn't find a thing does not help much.
> If you own the car: Do your own scanning, chech engine temp data PIDs
> If you lease: CYA! Document the failures and attempts.
That sets suspicion on the sensor side, unless you can locate a known repair TSB.
Are you familiar with MB leaky sensors ?
Usually it involves engine oil in ECU harness... Inspect for sign of coolant in sensor connector and ECU harness.
If that error was random, the fault would be archived by date and mileage.
It's up to who looks at all these data to act on them, spend the time to understand the issue or mess with the wrong parts and get a call back...
it's better to work on $800 oil change and $2500 brakes: no challenging wizardry!
Give the dealer 2 fair attemps then reach for the Service Mgr and MBUSA well within your warranty coverage.
Have you heard about "Diagnose Dan"?
He's a Deutsch wizard that fixes these sort unusual German problems.
Local dealers send him their worst headache cars...
Do you get fan constantly going regardless of Winter/Summer ?
As for your question - If i'm understanding correctly - It should keep it cool until it needs to kick on the fan... Not sure how to answer that. The temp sensors tell the fan when to kick on if they need to. New thermostat or not.
