Help with memory seats in W213 coupe
Hi, picked up my first Mercedes today and very pleased with it so far. The interior is very nice!
I do have one issue however and cannot find the answer after 4hrs of internet searching so hopefully you guys can help!
my memory seat buttons 1,2 and 3 don’t move the drivers seat, they move the steering wheel however nothing from the seats. The seat also doesn’t move forward when the handle is pulled for someone to get in the back.
I can move the seat using the buttons so I know the seat functions perfectly just not the above memory and rear access. Can anyone please help me?
passenger seat works exactly as it should.
Received 2,453 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
If pulling the handle doesn't work, try tilting and pushing it a little towards the front for the mechanism (or likely a sensor) to sense it, then the seat will start to move forward.
The memory seats is probably set to the previous owner's preferences, adjust your seat to your liking and then press M once and then press 1 or 2 or 3 and you will hear a tone. That confirms memory seat position 1 or 2 or 3 depending on which one you chose has set to it.
Received 4,435 Likes
'71 Pinto
No such model as 213 coupe depending on your market location either 207 or 238 post your VIN. If setting memory properly some have reported rear access malfunction resolved by replacing seat switch may also be the reason for memory seat function malfunction even though seat moves fine. For definitive diagnose have some pull fault codes, reluctant to do so with VIN I can pull switch part #.
