E-Class (W213) 2016 - 2023
Retrofiting cluster black issue
Old Dec 30, 2021 | 05:58 PM
Weblounge's Avatar
E220 coupe
Good night
I but a used digital display to replace the analog...the replacement was not complex, the kilometers appeared with ------ (normal from what I read here)
the problem is that right side screen doesn't turn on...
everything works fine but image not appear ...
I saw in another post that the screen needs coding ... can someone clarify what this is?
Can someone help me?
thanks
Left side ok
Right side black
Kilometers——
Old Dec 31, 2021 | 02:36 PM
kingscorpian27's Avatar
MB W213 E300 4MATIC Luxury Model
Originally Posted by Weblounge
Good night
thanks
Left side ok
Right side black
Kilometers——
That’s correct, you will need to get someone to do the coding for you. Coding is configuration of software to work with the car and new digital screen. I doubt the dealer will do that for you. You need someone with a MB diagnostic tool that can do the coding. Where are you located?
Old Dec 31, 2021 | 02:55 PM
Weblounge's Avatar
E220 coupe
thanks for you reply
i stay in Portugal
another member say me that necessary change audio 20 to command ntg 5.5… not necessary?
Old Dec 31, 2021 | 03:05 PM
i stay in Portugal
That maybe the case. Dealer in the US will only update software if you are having issues.
