Dead battey issues…
The quickest way would be to retrain the memory using the save button. Then test if you can recall your saved memory position afterwards.
The long way would be to diagnose what module is acting up: seat memory module, seat control module or anything else on the crowded CAN-B. Use a scanner to work these faults.
Low battery voltage directly promote com faults. Get that under control with a full charge or a new battery. Buy a jumper-pack because you can expect a flat battery after your next week off vacation (disconnect GND strap will help then).
I don't think the battery drain (sleepless F-SAM) and seat memory are directly related.
From what I gather on the internet thus far I have to take it in to have the seats normalized or something….what a pain in the *** over a dead battery….
Memory recall works except for the driver seat position...
Your seat module may need attention. This module is known to act up and discharge batteries. It builds crusties from ambient condensation and has to deliver high currents to seat motors from tiny conductors.
Use a OBD scanner to see what's happening...
There is a nearly identical twin named "passenger seat module" it has 95% similar components in a similar environment.
