E-Class (W213) 2016 - 2023
won't start-Restraint System Malfunction Consult Workshop
Old Jun 27, 2022 | 10:14 AM
zwei 97's Avatar
w213
Unhappy won't start-Restraint System Malfunction Consult Workshop
Hey guys,
Need help please, my W213 E200 won't start, get the error Restraint System Malfunction Consult Workshop/Auxiliary battery malfunction when I tried to start it. My diagnosis tool shows the code below:
U300E00
U010187
B214B72
U011187
U014600
I have replaced the Auxiliary battery, Battery but it is still not able to start up. Anyone else had this issue? Is there anything I can check as I think the actual error sometimes is not the actual problem??
Thanks in advance
Old Jun 29, 2022 | 02:02 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
bad PreFuse...
check out attached pdf... looks like your preFuse main relay is toast, likely from high currents overheat.
File Type: pdf
Old Jul 14, 2022 | 09:33 AM
zwei 97's Avatar
w213
I have replaced the Sam control module and the prefuse main relay. But It still not able to start up
Old Jul 14, 2022 | 02:08 PM
Are there any faults left after coding parts in?
