Hello, I have an e class w213 from 2017 and I encountered the following problems 1- the defogging in the mirrors does not work, both right and left, I looked in the mirror, I don't have broken wires or anything, maybe it's a safety issue but I don't know where is it.
2- the lower bulbs in the mirrors, which should light up when I unlock the car at night, don't work either, both right and left.
Have you encountered any problems like this before? Thank you!
Good job laying out your mirror issue. This seems like a bad connection between the door computer and the mirror.
Specifically a bad GND because its common to both these functions!
> Suggested troubleshooting:
Scan driver door computer for faults
Disconnect system battery
Pull out the door panel...then:
Open up the Door Control Unit!
Inspect connections for signs of poor contacts
inspect mirror harness for signs of water oxidation
