9g-tronic auxiliary oil pump replacement
Hi, I have error code in Xentry that the 9g-tronic transmission auxiliary oil pump is defective, also start/stop does not work (probably due to this).
I will change transmission fluid and filter and plan to change the oil pump in the same time, I only need to buy the correct part before.
Is the auxiliary oil pump the same A7259060800 in all 9g transmissions or is there several different?
if several exists, how can I find out which is the correct one for my S213 220d 2016?
Received 4,435 Likes
'71 Pinto
Confirm this is your VIN:
![](https://cimg6.ibsrv.net/gimg/www.mbworld.org-vbulletin/1301x494/capture_fb7bb3fd614d352ee38ceb89f24bb35ddff44da8.jpg)
MantaTIC (08-23-2022)
thank you!
When checking eBay it seem as it has 3 different numbers:A7252709307
A7252701301
A7259060800
do you know if all fit, if one is later version etc?
im asking since the price for new A7259060800 is same as for used A7252709307
A7252701301
A7259060800
'71 Pinto
7259060800 is not coming up in EPC, 7252709307 is current and correct for your VIN.
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/656x250/capture_cb045c95a135c508acae3dbbb031aee1a4ff6782.jpg)
MantaTIC (08-24-2022)
![](https://staticssl.ibsrv.net/autocomm/Content/MB/mbwambassador2.gif)
Received 3,930 Likes
2017 GLE350 4MATIC
Call your local dealer, and search using mbparts.mbusa.com
Just pulled apart the gearbox and the auxiliary oil pump installed is marked with A7259060800. Even there is no match in EPC this is the number on the actual pump.
'71 Pinto
Odd. Have you found replacement with that part #.
'71 Pinto
