Ignition Control Module
I have Mercedes e350 w213 there is issue with Ignition Switch Control Module damage by water but car starting but dashboard no display and car take time to off.
I bought used parts same part number put i can't program it by using AUTEL MAXIIM IM608 also if you have any solution online programming or by device
Ignition Control Module A2139008520
or any one face same issue
THANK YOU
If you can't get a place to virginise the used unit... you'll need a new unit programmed by a licensed business with online Xentry account.
solderless pins 😏
water damages 👎
oxidation bridges 🧐
The pics you posted show what water damages are and the amazing solderless pin connectors.
FIX the cause...
Don't forget the fix is not only about the modules and wiring but the source of the water leak... loose windshield??
So honestly (nothing to lose at this point).
Find the highest purity Isopropyl Alcohol \.. grab a plastic bristle brush and go to town. The white marks looks like salt/lime which is pretty conductive but the alcohol will take care of it.
