Is "A" Service Necessary?
Is the A service really necessary at this point, or can I skip it, and if so for how long?
My cost per mile driven is already through the roof due to insurance and so forth, and I'd kinda like to keep it under $5/mile! 😱
The B service is oil and filter, cabin filter changes and brake fluid:
In my opinion the chances of condensation in the oil is overstated: I had a Porsche Boxster which required oil changes every 15,000 miles. I was driving the car less than 1,000 miles a year. I did one oil change in 11 years of ownership and never had any problem.
Cabin filters: this is mileage not time: If you are not driving your car the cabin filters will not get dirty.
Brake fluid: I have a 2018 Ford Edge Sport (now the ST - High performance). There is no change in brake fluid. Ditto with most Japanese, Korean and American cars. I do not think that Mercedes is using some special brake fluid, unique to Mercedes that requires changing every two years. What I do think is happening is that in Germany on the autobahn there are no speed limits. Braking from those high speeds can cause the brake fluid to boil. Hence in Germany where high speeds are common it might make sense and to be on the safe side, to change your brake fluid every two years. For the rest of the world, every 20,000 miles seems overly protective and probably every 40,000 miles is more than sufficient.
I often wonder why the service intervals for German cars are so different than all other cars. This results in notoriously high maintenance costs. Again using my Ford Edge Sport as an example:
Spark plugs every 100K miles: Mercedes every 50K
Brake fluid never: Mercedes every two yeas
Transmission fluid: 100K miles: Mercedes 60K
In fact for the first 100K miles the routine maintenance is oil and filter, and cabin and engine filter.
Keep in mind that the engine in my Ford is a 2.7 liter Eco boost, 335 HP vs. my E450 3 liter 362 HP: so the engines are comparable;
I just changed the cabin filter in my Ford: Took less than two minutes: I checked Youtube to see how to change the cabin filter in my E450 and it looks like a 20 minute job crawling into the passenger side - totally ridiculous.
Engine filter on the Ford, less than 2 minutes. Again form Youtube, looks like a 30 minute job.
I often joked there is a reason the Germans lost the War: they have a particular ability to make easy job very, very complicated and hard.
...using my Ford Edge Sport as an example:
https://www.mbusa.com/en/owners/serv...%20replacement
Saying that fluid changes may be recommended, when they are not, is misleading and irresponsible. I own the Ford: I have the read the recommended services: they do not provide for the periodic changing of brake fluid.
If you have information to the contrary, that regular changing of the brake fluid is required, please post:
From the second line in this link directly from Ford:
https://www.ford.com/support/how-tos...d-brake-fluid/
occasionally changed, if the following occur which I have set fort in detail:
If your brake fluid looks a little low, here’s how to top it off.
- With the engine off, raise the hood and find the brake master cylinder. It is usually in the back of the engine bay, on the driver’s side.
- Cover the fender before opening the brake master cylinder and use caution when opening a container of brake fluid, as it can damage your vehicle's paint.
- Use a cloth or towel to clean the master cylinder’s reservoir and cap to prevent dirt or water from entering while you service it. Clean the fluid lines too, if they need it.
- Look at the fluid level on the side of the master cylinder’s reservoir. If your brake fluid is at or above the “MIN” line, your brake fluid level is fine and you don’t need to add any.
- If your fluid is below the “MIN” line, carefully pry the reservoir cap off, and then add brake fluid until the level is just under the “MAX” line. Do not overfill.
- Using a completely clean towel or a lint-free cloth, clean the inside of the reservoir cap: It may have brake fluid, dirt/debris, or both on it, and needs to be clean before you put it back on.
- Carefully set the reservoir cap on the reservoir, and press down on all four corners until it clicks into place.
- Visit your local Ford Dealership to have your brakes inspected as soon as possible—especially if your fluid level continues to go down, or if your fluid is dark. You may need your brake system serviced.
"occasionally", in common usage means when necessary and that will vary on how you use your vehicle and where.
So if you are not losing any fluid, the brake pedal responds properly, there is no brake fad, Ford does not recommend regular changing of brake fluid.
If the fluid turns black and shows contamination you will have to change it.
If you cannot stop and are low on fluid you have to change it.
If your car sat in garage for the past 20 years, has not been driven, I would say change it as well.
But under normal circumstances, with no fluid loss and the fluid has not turned color and there is no brake fade, then Ford does not recommend that you change the fluid.
Hope this clarifies!
- Mercedes-Benz motor oil replacement
- Oil filter replacement
- Fluid level checks and corrections
- Tire inflation check and correction
- Brake component inspection
- Reset maintenance counter
Back when I was doing track days with BMWs I'd bleed the brakes before every session. Having the brake pedal go to the floor when the water boiled is no fun. Watched a guy leaving the track in his Ferrari Boxer find out when he punted a Ford Fiesta when it happened.
