E-Class (W213) 2016 - 2023
Additional DRL lights
Old Dec 17, 2022 | 07:41 AM
felosargsyan777's Avatar
2018 W213
Hi.
I want to install additional DRL light on my car in front and i need to get wiring diagram or color code to know were the drl cable on headlight wiring harnes is. Car have none multibeam-headlights.
VIN: WDD2130051A343485
Thanks.
Old Dec 17, 2022 | 08:30 AM
Bfgslkman's Avatar
From: Northern Germany and sometimes Southern Germany
Mercedes E220d AMG Line Estate (S213) and Mercedes E220d AMG Line Cabriolet (A238)
Each to thier own, but the drl in the headlight is all controlled by coding. For example, you can change the existing drl to be with turning light or use the dip beam instead. you can even turn on the rear lights with the drl (which I have). maybe that might better suit your needs?
Old Dec 17, 2022 | 02:07 PM
2018 W213
I want to mount DRL lights like this:
but isn't there a specific cable in the wiring harness so I can connect them to it? I know I can connect to the rear lights, that's what I did with the diffuser light, but I don't want to run wires from the engine compartment all the way to the trunk.
Old Jan 5, 2023 | 03:35 PM
konigstiger's Avatar
'71 Pinto
MBUSA: left headlight (use pin out to identify wiring):
Right:
File Type: pdf
