OEM AMG Forged 19 inch Alloy ... A17740125007x21
1994 E-Class 320 Coupe, 1998 911 Carrera S (993)
I've admired the forged (lightweight) AMG wheels available on the late model E63s wagons. .. One such style was the 7-dual spoke AMG forged wheel. Here's a link to that wheel in a smaller-sized 19-inch wheel; (8.5 X 19 inches w/ ET46) ...
The offset of 46mm of an 8.5-inch wide rim is within 2 mm less of the outside stock All-Terrain 8' X 19" ET 38 rim.
If not for a stupid price tag I'd be a buyer ... It's a good-looking silver Forged (lightweight) AMG alloy, Fits the E-450 All-Terrain, and is of OEM origin. ... What's not to like? $$ .. A nicely understated factory 19-inch silver rim.
https://classicparts.mbusa.com/oem-p...17740125007x21
Roweraay (12-29-2022)
Those wheels certainly look good for sure, and since they are forged, should be much lighter, while being wider. Based on a rough calculation, they would be pushing outward by around 5mm, I suppose, with an inch being 25.4mm ?
M. Schneider (12-30-2022)
'21,'22 & '23 All-Terrain 8" x19" ET38mm AMG 5-Spoke Wheel w/Black Accents - OEM
The proposed AMG Forged wheel measurement; is 19" X 8.5" ET46 mm .. The All-Terrain appears to handle the proposed 1/2-inch wider wheel (8.0" vs 8.5") mostly by pushing the rim/wheel to the inside wheel well by 14mm .. The outside wheel dimension/placement appears to shrink by 2mm from the stock ET38 wheel placement.
https://www.1010tires.com/Tools/Wheel-Offset-Calculator
Roweraay (01-01-2023)
Roweraay -
I'd sure like this AMG Forged alloy ,,, however, you have to be nuts at $6000. USD or even half (1/2) of that,,, for my money. .. A brother-in-law agreed to troll eBay.de and local German /Switzerland websites trolling for a used 2nd hand AMG wheelset.
Our '23 All-Terrain gets picked up at the NJ dealership on Tuesday the 10th ... New winter snow tires recently were fitted for the initial road trip to Colorado ... Come the Spring of '23 and I'll visit the Michelin summer tire dealer .....
Here in town, there are more than a few MB AMG E63 wagons with like-silver AMG 20" 7-double spoke alloys ..... Nicely Understated !!
AMG 7-Double Spoke Forged Wheel . . .
The above is an AMG E63s wagon fitted with its OEM AMG 20-inch 7 Double Spoke Forged Alloys . . . . The same AMG-Forged Alloy designed wheel in a smaller 19-inch version,,, It would look great on our All-Terrain.. My.02
I am looking for 20” Mercedes wheels that would fit the AT, and looking at E63s takeoffs. Even though the bolt pattern (5 x 112) etc match up, not sure if the AMG versions have a hub bore that’s different from (maybe larger than) the non-AMG AT.
M. Schneider (01-01-2023)
The 20” options are all staggered (larger wheels/wider tires in the rear), which improves the look of the car from the rear, and provides a wider contact patch. I believe the 245 wide tires in the rear, look too skinny on the AT.
The disadvantage of a staggered set is that the tires can not be rotated, but that’s a hit I am willing to accept.
